Adhesive Remover For Terrazzo Flooring? - Flooring - Contractor Talk
Old 08-20-2012, 09:51 PM   #1
jmorton's Avatar
Trade: Flooring, Remodeling, Construction Services
Rewards Points: 27
Ok, I'm on the hunt for an adhesive remover for terrazzo flooring. The floor currently has glue down carpet over it, which we are going to remove. Then we will attempt to remove as much adhesive as possible and see what she looks like.
I had spoken with another installer who had suggested a "Panda" product/remover? I am able to find little information on the product, let alone where to purchase it.
So I am open to suggestions from all of you more seasoned pro's.
Thanks.
jmorton is offline
Old 08-30-2012, 05:14 AM   #2
fcfc's Avatar
Trade: Flooring
Rewards Points: 81
Re: Adhesive Remover For Terrazzo Flooring?
The question I guess is this, is the base level flooring terrazzo? Has the glue down carpet been installed over it. Are you looking to restore the terrazzo and remove the adhesive residue? Or are you looking to simply make it acceptable for new flooring (and this makes a difference) what type of new flooring would be installed over this substrate)?
fcfc is offline
Old 08-30-2012, 07:52 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Taylor adesive remover, 1 qt $14.00, But most of the glue will come off with razor scraper. terrazo floors are real smooooooth, (flat)
sunkist is online now
Old 09-02-2012, 08:27 PM   #4
YUUUUP!
JWilliams's Avatar
Trade: Metal Roofing Mogul
Rewards Points: 916
I have a suggestion.. It's called very carefully!
JWilliams is offline
Old 09-03-2012, 05:26 PM   #5
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Unger razor floor scraper with a bunch of extra blades
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 09-15-2012, 09:29 AM   #6
MIKE ANTONETTI's Avatar
Trade: FLOORING CONTRACTOR
Rewards Points: 3,514
It will still be ugly terrazzo , but you will have prepped it properly to save glue for the new carpet.
MIKE ANTONETTI is offline
Old 09-21-2012, 09:24 PM   #7
So how's it look?, really terrazzo is not "ugly", it's just that a lot of colors are blah,
Today's terrazzo mixes are way more interesting using epoxy, colored glass, etc,
There are tons of houses in my area with terrazzo under carpet, tile , hardwood.
Durability wise it's an excellent product.
Then there is fashion, design.
Old 09-23-2012, 11:21 AM   #8
BKM Resilient's Avatar
Trade: Flooring
Rewards Points: 836
Thanks.
Terrazzo will probably require "refiinishing" after having been covered with carpet adhesive and carpet for a few years. I doubt there's permanent damage done by the carpet but often the carpet is there because of pre-existing issues they chose to "sweep under the rug."
It's highly improbable that you can get anything close to a professional restoration with hand scrapers, mops and local rental yard tools.
If your customer just wants a hack, scab job they can do that themselves or drive to the local Home Depot and pick up a handful of illegal aliens.
So there's such a trade as terrazzo grinding and finishing. There's some pretty expensive equipment needed and experience operating it and following standard procedures. Terrazzo has been around for over 500 years. It's made to last but it's not one of those "easy money" do-it-yourself trades like clicking together laminates or peel and stick vinyl tile.
BKM Resilient is offline
The Following User Says Thank You to BKM Resilient For This Useful Post:
overanalyze (09-23-2012)
Old 09-23-2012, 07:03 PM   #9
Also adhesive may have soaked into the white Portland and marble chips and stained to 1/8" deep
Need one box of Easylock II or Swiftlock Red Cherry laminate flooring. Ethos Flooring 1 06-04-2012 03:01 PM
Heavy duty adhesive remover Greg Di Vehicles 11 03-26-2010 01:24 AM
Bruce EverBond flooring adhesive? curapa Flooring 1 11-24-2007 03:33 PM
