When it comes to siding, not a lot of people know about board and batten. Commonly used as a siding technique on barns, board and batten has since come into popularity for residential homes as well. Let's have a look at what makes board and batten such an interesting option, and why you should use it for your home.
Board and Batten is Long Lasting
While other types of siding such as traditional horizontal installations can require a bit of upkeep to maintain, board and batten does not. As long as everything about the installation went smoothly, you can expect your board and batten siding to hold up for many years.
Board and Batten Siding Adds Value to your Home
One of the main reasons people choose to install board and batten steel siding is that it looks very stylish. Although originally designed for barns, builders have perfected the art of applying board and batten to residential homes as well. A well-done installation will add some serious style points to your home, and you should see that reflected in its overall resale value when the time finally comes for you to sell. If you do decide to go with steel, the metal siding colors are abundant.
Board and Batten Siding is Very Cheap to Maintain
The cost of installing board and batten can vary widely, depending on what kind of material you use, how big your home is, and what your labor costs are like. One thing that remains consistent, however, is the cost of repairs. Board and batten uses individual pieces rather than large sheets of siding, making it very cost effective to maintain should you need repairs.
Make the Switch Today
If you were on the fence about board and batten siding, hopefully this article helped convince you to try it out. With an increase in resale value as well as cheap repair costs and long-lasting value, it's hard to see why you wouldn't!
