As a contractor, you need to be prepared for as many situations as possible to do your best at each jobsite. Unsurprisingly, just learning how to read a tape measure isn't going to cut it. Just as having the knowledge and problem-solving skills is mandatory, having the right tools to perform your work is essential for success. While there can never be a comprehensive list of every tool needed to handle all aspects of contracting and guides to construction measuring tools, comparisons, etc, having the following basic tools in your tool kit can make you a versatile contractor ready for most jobs.
Carpentry
Carpentry is essential to all types of contractual work due to the structures that must be modified for all building materials.
- Clawhammer
- Corded/Cordless Power Tools (i.e. drill, circular saw, nail gun)
- Saw Horses
- Clamps
-Choose a Level for Masons
- Framing Square
- Screwdrivers (flathead, Phillips head, etc.)
- Ladder (single pole, extension ladders)
Plumbing
Plumbing elements can become involved with all sorts of projects, even when not expected.
- Pipe Cutters
- Level (laser or bubble)
- Hacksaw
- Pipe Wrench
- Thread Sealants (teflon tape, sealing compound)
Electrical
Dealing with electricity is always part of a contractor's work, even if this means power tools and lighting. Subsequently, the ability to work safely with electricity is a must with the following tools:
- Electrical Multimeter
- Electrical Tape
- Hardware (Wire of various gauges, nuts, connectors, crimps)
- Soldering Iron
- Wire Strippers (with crimping capabilities)
Safety
Staying safe is essential for all contractors, whether this means preserving the structure, calling for emergencies, or preventing bodily harm.
- Communication Device (Cell Phone, 2-Way Radio, etc.)
- Fire Extinguisher (up to date)
- First Aid Kit
- Personal Protective Equipment (i.e. gloves, hard hats, ear plugs, safety goggles)
- Safety cones/markers
Miscellaneous
- Paintbrushes
-Wide Blade
- Tarps/Clothes
- Heat Gun
- Ladders
- Paint Thinning and Cleanup Wares
-Steel Long Tapes
- Rags
- Roller Kit
- Adhesives (pool table repair, etc.)
-Pocket Rods
- Wire Brushes
- Spackle Knives
-Diameter Tapes
- Sanding Equipment (sand paper, powered sander)
Carpentry
- Clawhammer
- Saw Horses
- Clamps
- Framing Square
Plumbing
- Pipe Cutters
- Hacksaw
- Pipe Wrench
Electrical
- Electrical Tape
- Soldering Iron
Safety
- First Aid Kit
Miscellaneous
- Paintbrushes
-Wide Blade
- Tarps/Clothes
- Heat Gun
- Ladders
-Steel Long Tapes
- Rags
- Roller Kit
-Pocket Rods
- Wire Brushes
- Spackle Knives
-Diameter Tapes
