7 Kitchen Design and Remodeling Ideas
July 08, 2019
No-avatar-62
  • Activity
    Log
  • Blogs43
  • Forums0
  • Projects0
  • Reviews0
  • Toolbox0
A kitchen is one of, if not the most frequented place in any household. We spend a lot of time opening the same cabinets, using the same countertops, and operating the same equipment. That’s why if you want to avoid “kitchen fatigue” you need to switch it up every so often.
I’m not just talking about rearranging your table and a few items, either. A little remodeling can go a long way towards making you feel like you’re living in a totally different house.
For those of you who want to break the monotony and freshen things up in your kitchen, here are 7 kitchen design and remodeling ideas to help you do just that.
1. Replace Outdated Flooring
Kitchen floors are very quick to wear out and become old-looking. One of the best ways to revitalize your kitchen is to replace the flooring. One great option is to install new hardwood flooring. Wood floors look amazing and they’re surprisingly durable as well. You could go with a reclaimed wood accent if you want to be stylish, or keep it modern with American, or European-style wood floors. Consider grey wood flooring over a natural wood finish for a more modern design.
2. Revamp Your Cabinets
Cabinets don’t typically see as much wear and tear, so a quick and inexpensive way to give them a makeover is with a fresh coat of stain or paint. If you’re doing multiple remodeling projects in your kitchen, choose a color that meshes well with your floors, ceiling, and appliances. This is an easy way to achieve a whole new look in your kitchen.
3. Add Under-Cabinet Lighting
Another way to make your kitchen feel brand new is to add some under-cabinet lighting. A lot of kitchens only have ceiling lights and under-stove lights, so adding some bright new lighting in new areas will not only look better, it will serve a functional purpose as well. Some popular choices for new under-cabinet lighting include puck lights, xenon fixtures, fluorescent fixtures, LED fixtures, and LED strip lights.
Some of these options such as LED fixtures, puck lights, and xenon fixtures are dimmable, which is great for adjusting the atmosphere of your kitchen depending on the occasion, or your mood. Others like LED strip lights and fluorescent fixtures are brighter, making them less likely to leave “dead spots” around your kitchen.
4. Update All Hardware
Updating many small things at once is also a very effective way to make your kitchen feel brand new. Change out your cabinet handles, kitchen faucets, light fixtures, and anything else that can be easily removed and replaced. For maximum style points, choose a theme or color and stick with it for everything you replace.
5. Choose a Durable Countertop
Countertops take a lot of abuse, especially if they’re made out of wood and plastic, marble, or other softer materials. Quartz is an amazing choice here because it resembles, and arguably surpasses the beauty of marble while being more durable and stain-resistant.
You can even have some say in the pattern and coloring of quartz countertops because they are manmade, as opposed to marble which you normally have to accept warts and all.
6. Invest in a Multipurpose Island
This is another way to make you feel like you’ve walked into a completely different home. Adding a multipurpose island is great for introducing more seating space for bigger families or families who like to have guests over. It can also serve as a bonus space for you to cook, store wine, or anything else that comes to mind.
7. Add an Accent Wall
If you have the space, or you’re willing to make the space for it, adding an accent wall will totally change the look and feel of your kitchen. You could go with a chalkboard paint accent, stone or brick accent, or just use some decorative wood wall panels for your design.
Your Options Are Endless
When it comes to spicing up your kitchen with some new design and remodeling ideas, any of the 7 mentioned here should do the trick. Of course, you might want to combine a few of them, depending on how brand-new you want your kitchen to feel. New lighting, flooring, hardware, cabinet colors, or countertops can bring a totally new style and flair to your kitchen while also giving you improved functionality.
Adding a multipurpose island or an accent wall can also really change up the dynamic of your kitchen, allowing you to give it new life and enjoy countless hours of cooking and family interaction for years to come.
Comments (0)
or to comment
    No results found
    ContractorTalk is for
