Swimming Pool Demolition
Old 02-14-2017, 02:26 PM   #1
greener's Avatar
Trade: remodeler
Neighbor is currently building a new house and demolition started yesterday on a house built around 1960 when concrete was dense. They brought in a large excavator and instead of using a jackhammer or something similar to break up the concrete first they are lifting huge multi-ton chunks and dropping them from about 30+ feet to break them up. My house is 3 houses down and it felt like a sonic boom and shaking the house.
We are in Los Angeles.
Can anyone advise if this is standard procedure? Seems they are not only unsafe but breaking some code.
thanks.
greener is offline
Old 02-14-2017, 05:56 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,168
Re: Swimming Pool Demolition
Why ask here ?, why not call the city they are the AHJ.
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
SmallTownGuy (02-14-2017)
Old 02-14-2017, 06:15 PM   #3
tgeb's Avatar
Rewards Points: 378
Sometimes the best way to bust up concrete is with concrete, I've dropped plenty of big ole' chunks on bigger chunks until they become manageable small chunks.
I doubt you would have been happier with a demo hammer busting things up.....now that's noisy. Ear plugs for the operator and crew noisy.
www.gebcon.com
tgeb is offline
Old 02-14-2017, 06:44 PM   #4
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 6
Not in the demolition field, BUT, there are articles online about the very real hazards from improper demolition. One example is using the bucket of backhoes like a jackhammer...creates shocks in excess of some small earthquakes, and violates operators instructions for the machinery. It sounds nit pick, but when you own an 1880's building like mine, or apparently even yours, very real damage to other structures can happen from over-shaking the ground. One article I found was about damage during some road project. You should be able to turn up these articles, I don't have them bookmarked. Unfortunately, I don't know what relief you can seek. My situation was our city hitting the pavement outside my building with the bucket of a backhoe and just like you said, it was unnerving, few things fell off shelves, etc. Granted my building will fall down in an earthquake, but we don't need to speed it up.
P42003 is online now
Old 02-14-2017, 06:46 PM   #5
Business Owner
P42003's Avatar
Rewards Points: 6
I never would have understood your situation had I not experienced it myself. The noise I could deal with, but the shaking was on the order of a Magnitude 2 earthquake (I am comparing this to a Magnitude 2-3 earthquake that hit 40 miles from here last year). Guys doing demo need to remember the formula for Force, which is mass x velocity. The acceleration of the slab blocks isn't as much factor in your situation as the mass hitting the ground. Same deal with the bucket head, though with a little more speed. The jackhammer is several magnitudes less mass, but very fast velocity...breaks up points of impact but doesn't shake the ground like the two other examples.
Old 02-14-2017, 07:35 PM   #6
slowsol's Avatar
Rewards Points: 2,200
It's dangerous. Probably common among guys that don't have the right equipment.
-John
slowsol is online now
Old 02-15-2017, 11:27 AM   #7
greener's Avatar
Trade: remodeler
Would have much preferred the noise of a jackhammer to break up the smaller pieces than to drop these enormous chunks that shake the neighborhood and possibly causing damage. Seems the demo contractor did not want to take the time to do this responsibly considering the age of the two houses bordering the site.
Just wanted to ask the question on best/ responsible practices in demo .
thanks very much
greener is offline
Old 02-07-2018, 09:47 PM   #8
Minerrick's Avatar
Trade: Demolition
Rewards Points: 32
Another option for demo is a device called a Sierra Blaster. It's an electrically fired blasting system, that doesn't need an extensive ATF license. I use it at my mining claim and for breaking up rocks and concrete at construction jobs. The charge costs $1.50 and it is waterproof. An example of its power is I can drill a 4' diameter rock 12" in and set the charge. I stand back 20 feet and set it off- no fly rock, and no loud explosion, and the rock will shatter into 5 or so manageable pieces. This is a new invention and I have probably 2 full years of experience on my mining claim and using it for concrete demo. Very cool, and you won't get any complaints from the neighbors if you throw a painter's tarp over it, no one will hear the shot. There is nothing like it on the market. http://www.sierrablaster.com/rss-landing/
Minerrick is offline
The Following User Says Thank You to Minerrick For This Useful Post:
kirkdc (02-07-2018)
Old 02-07-2018, 10:47 PM   #9
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,734
Come up here in the Rocky Mountains when they blast with dynamite to run water lines, install septic, etc.
Some backhoe operators have some pretty evil looking dippers with Mad-Max prongs on them and can often break up the underlying rock. But when that fails or if it's solid bedrock, out comes the dynamite.
Sierra Blaster? Sweet. I'll have to ask around and see if guys are using them here.
kirkdc is offline
Old 02-07-2018, 10:52 PM   #10
Minerrick's Avatar
Trade: Demolition
Rewards Points: 32
dynamite has its place as do other forms of demo. But where you are in a "delicate"situation, with the potential of being sued because of your jackhammering or other explosives causing damage to the neighbors, there are lesser alternatives. I often get called in to do jobs where there are boulders in ditches that extend under foundations- so rather than risk damaging the foundation, I spend about 15 minutes on the job and the excavator gets back to work and I am on my way.
kirkdc (02-07-2018)
Old 02-08-2018, 01:16 PM   #11
Fishindude's Avatar
Trade: Industrial
Rewards Points: 244
Yep, some hillbilly demo guy trying to make do with what he has, and too cheap to rent or buy the proper equipment.
Fishindude is offline
Old 02-08-2018, 04:47 PM   #12
hdavis's Avatar
Rewards Points: 4,629
Excavator with Jack hammer on it. Takes it out fast in whatever size pieces you want.
Pools are nothing but shotcrete and steel, it's pretty tough. Around here, you may be paying for foundation cracks.
hdavis is online now
greg24k (02-09-2018)
Old 02-08-2018, 10:54 PM   #13
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,836
and you want to know why??
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
If I have a California c-53 license (Swimming Pool Contractor) PoolRepairsOnly Contractor Licensing 1 12-11-2012 12:23 AM
Question on compacting soil around a pool BCConstruction Masonry 14 09-26-2012 06:38 PM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 07:48 AM
