Slab Demolition
Old 02-05-2010, 08:10 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Slab Demolition
Which jackhammer would be more expedient to demo this 10' x 11' slab? An electric one cost $100/day to rent, an air one is $220/day. How long do you think it would take for each?
KennMacMoragh is offline
Old 02-05-2010, 08:12 PM   #2
Warren's Avatar
Trade: framing/remodeling
Re: Slab Demolition
I have never used an air hammer. An electric one would do that in a few hours I am sure. We have rented them on several occasions. If you rent the air one, you will have to have a gasoline compressor large enough to power the hammer.
Warren is offline
Old 02-05-2010, 08:25 PM   #3
Re: Slab Demolition
O.k thanks, the $220/day includes the compressor, hose, and everything for it. But yeah that's what I was thinking, that the electric would take care of it quick.
Old 02-05-2010, 08:37 PM   #4
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: RESIDENTIAL CONTRUCTION, BUILDING & PROPERT MAINT.
Re: Slab Demolition
I rent the electric ones all the time. Enough were I think i might buy on this summer. I can hammer out a 24x24 garage slab, 6" thick, and clean up all debree in a 8 hour day with 1 helper. so that one you got should only take 2-3 hours. good luck
mnjconstruction is offline
Old 02-05-2010, 08:39 PM   #5
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Re: Slab Demolition
CONCRETE MIKE is offline
Old 02-05-2010, 09:32 PM   #6
DBCoop's Avatar
Trade: Trim Carpenter-Wood/Chain Link Fence Construction-Concrete Construction
Re: Slab Demolition
I have an electric Hitachi and it works well for a 4 inch slab. My thoughts would be go electric. ( Bosch or Hitachi ) Is there rebar in the concrete? If so your time frame will be expanded!
DBCoop is offline
Old 02-05-2010, 10:00 PM   #7
dayexco's Avatar
Re: Slab Demolition
armstrong it with an 8 lb. sledge and put the $200 in your pocket and get in shape...put your man pants on!!!!
dayexco is offline
The Following 6 Users Say Thank You to dayexco For This Useful Post:
aptpupil (01-12-2011), DBCoop (02-06-2010), griz (02-05-2010), peteo (03-22-2011), scrapecc (02-06-2010), WildWill (12-17-2011)
Old 02-05-2010, 10:10 PM   #8
Shawn Prentice's Avatar
Trade: carpenter/remodeler
Re: Slab Demolition
I agree. Something that small you could have a good start breaking it up up in the time it takes to pick-up and drop off the electric one, unless the rental store is real close.
Shawn Prentice is offline
Old 02-05-2010, 10:20 PM   #9
Re: Slab Demolition
DBCoop, that was one of my concerns was whether or not there's rebar in it. However, I doubt there is judging from how the slab has settled. And I just did a water damage renovation on this house, it looked like this house was built by farmer Joe, just hacked together. And it was built in the 50's, so I doubt they put any rebar in their patio.
That's why I wasn't sure on what to use or how to bid. I will just have to prey I can get it chipped out in half a day, rental costs really add up if it takes more than a day.
Dayexco, I don't know if you're serious. But yeah I've actually seen people start out with a sledge hammer trying to demolition a whole driveway, then they give up and get a jackhammer.
The Following User Says Thank You to KennMacMoragh For This Useful Post:
DBCoop (02-06-2010)
Old 02-05-2010, 10:34 PM   #10
SEMI RETIRED
griz's Avatar
Re: Slab Demolition
I've got a Bosch Brute (electric) that has demo'd several slabs larger than what you have. Does the job with re-bar also. If you go electric use a big enough extension cord.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
DBCoop (02-06-2010), Mud Master (03-19-2011)
Old 02-05-2010, 11:11 PM   #11
Rockmonster's Avatar
Trade: Masonry
Re: Slab Demolition
If you go electric, probably 3 hours and your done....if you go air, you'll have it busted up in 8 minutes....and if it's only 2 1/2 inches, then maybe you could think about a sledgehammer....I would probably go electric, it will be quick enough, and you won't go deaf in the process...gl
Rockmonster is offline
Old 02-05-2010, 11:17 PM   #12
Designer/Contractor
Rio's Avatar
Re: Slab Demolition
We have a Makita 60lb (I think) and it works well. You could do it by hand too. We use the Makita for all sorts of stuff. I loan it to an electrician friend of mine to drive ground rods; we have a lot of adobe here and it'll cut right through it when we need to cut through that stuff...........
Rio is offline
Old 02-06-2010, 06:05 PM   #13
DBCoop's Avatar
Re: Slab Demolition
Kenn. It will be what it will be .......... go with your instincts !
DBCoop is offline
Old 02-06-2010, 06:22 PM   #14
Twisted Cameron
scrapecc's Avatar
Trade: Concrete, Metal buildings
Re: Slab Demolition
Something that small shouldn't take more than 3 hours with a sledge. I would never spend the money on a hammer for that small of an amount of concrete. Unless its 6 inches thick. Its just a little sledge hammer party. I always love a party!
scrapecc is offline
Old 05-13-2010, 11:19 PM   #15
bernardoconcret's Avatar
Trade: concrete
Re: Slab Demolition
An electrical hammer would work just fine for this small area.
N. Perez
bernardoconcret is offline
Old 05-13-2010, 11:31 PM   #16
robert c1's Avatar
Trade: remodeler/gc
Re: Slab Demolition
What did you end up doing?
I'm guessing most people already know the technique but I'll say it anyway.
The trick is to lever them up and slide a fulcrum underneath (2x4 works just fine).
Then it's just a few strikes along the line of your 2x4 and the waste side will fall off.
robert c1 is online now
Old 05-13-2010, 11:57 PM   #17
Chuck
S.R.E.'s Avatar
Trade: Excavating, Clearing, Underground Utilities
Re: Slab Demolition
You have probably already taken care of this, but for the future they make a gas powered jackhammer that rents for about 75.00 a day that works pretty good on small jobs. You know the ones were you would like the tow-able compressor with a 90 lb. jackhammer but it's not cost effective.
S.R.E. is offline
Old 05-14-2010, 12:12 AM   #18
Re: Slab Demolition
I used an electric jackhammer, it worked fine.
Hmmm, I pulled them off piece by piece with my hands. I can't really envision what you are talking about, I just make sure the chunks have somewhere to go for efficiency.
I think I would have looked like an idiot if I tried using a sledge. It was five or six inches thick, had a little bit of wire fabric reinforcement, and it was about 50 years old, that's when concrete reaches it's peak strength.
Originally Posted by framerman
Second, it is your career, not a job. Even better is that is it your passion, or your destiny.
Old 05-14-2010, 12:52 AM   #19
robert c1's Avatar
Trade: remodeler/gc
Re: Slab Demolition
Don't get me wrong, if I have a jackhammer handy I'm gonna use it.
Clear as mud huh. It's just a technique for breaking concrete. The limitation is you need to be able to lift the slab, if you can lift it you can break it. You lever up the slab and shove something underneath it about where you want it to break then strike the slab above the object. This weakens the bond of the concrete in that spot and gravity does the rest.
Old 05-15-2010, 12:56 AM   #20
Re: Slab Demolition
Ahh, yeah I can see that working on something small enough.
Installing a Door Slab CookeCarpentry Finish Carpentry 62 07-11-2010 08:23 AM
Flagstone over slab paulbronson Flooring 2 10-26-2009 08:15 PM
waterproofing the parking deck slab paulbronson General Discussion 1 10-23-2009 03:47 PM
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 08:25 PM
Walkout basement: Pavers on a slab? bert0168 Masonry 12 08-12-2009 06:52 PM
