How To Remove Plaster Walls
Old 05-19-2009, 07:47 PM   #1
Jordy3738's Avatar
Trade: Cabinetry
Not long ago I was involved in tearing out some living room walls that were plaster. This was the first time I had taken on a task like this.
The contractor gave me instructions on how to do it and after about two days I finally got the hang of it.
I used a hammer and a cats paw or Super Bar and plenty of dust masks for the first day. Oh yeah and a tough pair of leather gloves.
Then the second day I decided to borrow a sledge hammer from a friend.
I think the most challenging part of the job was getting the wire mess out of the corners. What a pain.
Any thoughts?
Jordy3738 is offline
Old 05-19-2009, 08:06 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: How To Remove Plaster Walls
Better you than me
naptown CR is offline
Old 05-19-2009, 08:19 PM   #3
Mellison's Avatar
Trade: Home Improvement General Contractor
Just watch the BX cable.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 05-19-2009, 08:23 PM   #4
Capra aegagrus
Tinstaafl's Avatar
That's fine if you have a week to do the job.
Jordy, I think you should buy your own sledgehammer and rescue that friendship.
Then find someone younger and dumber than yourself to do the next one.
Tinstaafl is offline
Old 05-19-2009, 08:35 PM   #5
Mellison's Avatar
I agree. If you have two guys cleaning for each one smashing. Otherwise it will be faster with alot less mess.
Mellison is offline
Old 05-19-2009, 09:41 PM   #6
dayexco's Avatar
WTF does this have to do with excavation and site work?
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
backhoe1 (05-19-2009)
Old 05-19-2009, 09:42 PM   #7
Grand Rapids Remodeling
Paulie's Avatar
At one time I had rental property and needed to gut the upper apartment to the studs (plaster/lath). Having done this nasty work before I tried to think of a better way. My solution, buy a keg, invite half a dozen buddies and give them all bowling balls I acquired from the local bowling alley.
The good news is that it got done in one long night of inebriation, bad news was waking up to a huge clean up that took about a week.
Paulie is offline
Old 05-19-2009, 10:22 PM   #8
dayexco's Avatar
one more time....WTF does this thread have to do with excavtion and site work?
dayexco is offline
Old 05-19-2009, 11:21 PM   #9
Moderator
Double-A's Avatar
I thought the beer and bowling balls tied it all in.
I guess I'll move it.
New York Times, July 20, 2006
Double-A is offline
Old 05-19-2009, 11:25 PM   #10
solar guy
naptown CR's Avatar
Its kind of like excavating the surface layer of dirt except it's plaster and inside and vertical
Old 05-20-2009, 10:22 AM   #11
Master Baiter
FowlOne's Avatar
Trade: Commercial/Residential Subcontractor
Easiest way i've found to remove plaster............get somebody else to do it
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. - Ronald Reagan
FowlOne is offline
Old 06-04-2009, 10:31 PM   #12
bathroom guru
jarvis design's Avatar
I normally use a 30" wrecking bar and a sledgehammer.
Oh, and 2 guys to use them!!
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
Old 06-04-2009, 11:05 PM   #13
KemoSabe
loneframer's Avatar
Any thoughts?
Yeah, try hanging a picture every so often, that s#!t will fall off the wall no problem.
loneframer is offline
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 06:43 AM
Interior brick walls old building converting to a loft apartment dakzaag Masonry 7 04-25-2009 11:29 PM
sheetrock vs. plaster in bathroom post and beam ceiling Bunc General Discussion 2 03-16-2009 09:34 AM
Sanding Walls with 80 Grit Paper on Orbital Questions plazaman Painting & Finish Work 5 12-19-2008 04:01 PM
Old plaster that won't hold paint hbiss Painting & Finish Work 14 07-28-2007 08:50 AM
