Trade: worker
Corner To Corner Slump
I was in a new home (2005) recently and it had eleven full height cracks in the foundation, too much water was added on site to the mix before pouring in my opinion. Corner to corner slump….
How often do most of you see this condition or witness the process being done. |
Re: Corner To Corner Slump
Don't think I've ever seen foundation cracks that bad, meaning bad enough to need repair. Only seen it in slabs. But yes, got to be careful on house foundations, no special inspectors are there watching them. They can put however much water in they want, and typically no one says anything.
Trade: Masonry consultant
Adding water is a very common fault with poured foundation contractors. The water makes their job easier since they let the concrete flow and do not vibrate. - I will bet it is not square either.
Where the cracks from the corners of the windows and in the middle of longer straight walls? Just hope he did not do any ICF walls also. That many cracks could even suggest some footing problems even if the cracks look like typical shrinkage cracks.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. Last edited by concretemasonry; 12-02-2008 at 02:44 PM. |
| instructions for aluminum coil wrapping an outside corner sill | t2tiam | Windows, Siding and Doors | 12 | 12-24-2008 12:44 AM |
| Need help with a bullnose corner with 8" crown | jayweitekamp | Finish Carpentry | 151 | 10-30-2008 10:33 PM |
| Black marks left by inside corner applicator | AARC Drywall | Drywall | 5 | 10-04-2008 09:41 AM |
| Stucco Corner Bead to Concrete Blocks | brenrobinsommer | Masonry | 3 | 08-28-2008 01:12 PM |
| unusual corner capstone to low ret wall | henhen11417 | Masonry | 2 | 07-03-2008 06:03 PM |
