Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Demolition
Old 06-11-2009, 09:05 PM   #1
Trade: Paving / Landscaping
Concrete floor removal
Hi guys. I have an interior concrete floor removal project that I would appreciate some input on. While my specialty is exterior flatwork, a good customer of mine has requested some help and a bid on repairing a floor that has settled inside a condo. An engineer has recommended removing the concrete floor and 24'' of stone/soil below the slab, to make room for fresh modified stone that will be properly compacted.
My first thought is using a mini-excavator teamed up with a power buggy to get the material outside. The total area is approximately 300 sq. ft. Only hesitation is worrying about carbon-monoxide poisoning. Have any of you utilized large commercial fans to keep the fumes blowing towards outside, or is that still a danger. I was also thinking of purchasing a few carbon monoxide detectors and mounting them in the work area as a safety.
What am I forgetting safety wise on this job, and any other thoughts that come to your minds? Thanks in advance.
joesauers is offline   Reply With Quote
Old 06-11-2009, 09:15 PM   #2
Slow Roller
Trade: Fan of Bodger
i wouldn't do it. mexicans and wheel barrows to get it to the outside then bobcat it.
Crock is offline   Reply With Quote
The Following 3 Users Say Thank You to Crock For This Useful Post:
Chris Johnson (06-11-2009), MattK (06-11-2009), rbsremodeling (06-29-2009)
Old 06-11-2009, 09:26 PM   #3
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
That job requires Manuel (Manual) labor, charge accordingly.
Chris
Chris Johnson is offline   Reply With Quote
Old 06-11-2009, 09:43 PM   #4
Trade: Remodeling general
They will probably be faster than the alternative
naptown CR is offline   Reply With Quote
Old 06-11-2009, 10:00 PM   #5
Trade: Framing
Ive used a bobcat in a raised ranch basement that had the garage underneath. It was right after frame so no door yet.
Anyway the fumes were toxic immediately. Youre fans arent going to do much with tremendous fumes from heavy equipment. Dont forget about the smoke in a confined space. Few of those diesel motors run clean.
Be careful with this job.
MattK is offline   Reply With Quote
Old 06-11-2009, 10:41 PM   #6
Trade: Mason Contractor
Rent a conveyor belt to get materials out and then you can use it to put stone back in.....
DJ9222 is offline   Reply With Quote
Old 06-12-2009, 08:48 AM   #7
Trade: Roofing, Siding and Custom Carpentry
Why not drill and jack the slab....probably be cheaper than taking out and replacing. I had a slab that settled about 4 inches in an entire home(due to a pipe break washing out fill) we had a company come in and raise the slab. It worked nice.
RandyB1986 is offline   Reply With Quote
Old 06-12-2009, 02:49 PM   #8
JonM's Avatar
I hope you forgot a zero...but if it is 300 sf carry it out in a bucket..
JonM is offline   Reply With Quote
Old 06-12-2009, 03:32 PM   #9
master of none's Avatar
Trade: carpenter
the fastest and easiest way I have ever removed concrete is to saw it into
3' x 3' chucks. Using a chain and some redheads lift them out with a backhoe or mini. Cleanest and fastest why ever. you can rent a big saw just make sure you cut it all the way through. If the money is in it I would sub this part out.
Abandon the search for truth settle for a good fantasy
master of none is offline   Reply With Quote
Old 06-12-2009, 03:33 PM   #10
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Sounds like a lot of furkin' hard labor
who dat is?
Darwin is offline   Reply With Quote
Old 06-12-2009, 03:43 PM   #11
Trade: Control Systems
Monoxide detectors are usless, the will go off constantly and drive you nuts; if you feel tired have a headache and sick get fresh air. Or rig your mini ex up with an exhaust hose.
3' x 3' chucks
Not a bad idea, tuck point blade in a quick cut should go through like butter; the last concrete floor I helped rip up we did with 2 jack hammers an conveyor belt and 2 guys carrying the pieces to the conveyor. I've had mixed success with hammers though, if its on a really solid surface then they work great, if its on a jello like dirt then the ground absorbs all the impact.
Inner10 is offline   Reply With Quote
Old 06-12-2009, 04:11 PM   #12
Professional Remodeler
firemike's Avatar
I agree with Randy, have you and the engineer considered slabjacking? Did they core sample the soil underneath to see if that much work is really needed or are they just guessing? It's gonna be a lot of work no doubt.
We did one once in a commercial building, did like Master of None except cut it into 2 foot sections and hand trucked them out to the loader. Took more time to cut than remove, but it did work great.
If it gets to this point, you're most likely too late, you already have CO poisoning. Expect to be puking shortly, and be sick for a couple days or so.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline   Reply With Quote
Old 06-12-2009, 08:21 PM   #13
General Contractor
greg24k's Avatar
My buddy had Concrete Slab Lifting System, I will try reach him tomorrow and see if he still has the equipment and doing this work. If he does I will post here and let you know Yes or No.
greg24k is offline   Reply With Quote
Old 08-20-2009, 09:59 AM   #14
Trade: home remodeling
I think you should use the mini- excavator for the job. You must do some sort of dust control though in order to get this done. I just had a similar job that required me to worry about fumes and dust. I hired people from Midwest Industrial Supply. It was worth it. It ended up saving me money compared to what I would have spent to sublet this job. Good Luck.
cc321 is offline   Reply With Quote
Old 08-27-2009, 08:49 PM   #15
Trade: Framing and General Construction
I know a mexican named Tarzan that makes minced meat out ouf concrete with a 20 lb sledge.. Not a joke either! I've seen him take out a walkway with the sledge and a crowbar faster than his helper could load it in the wheelbarrow! As for cutting I know a guy that died cutting indoors. the whole crew passed out and If I remember right he wasnt the only one that died
cbfx3 is offline   Reply With Quote
Old 08-27-2009, 09:52 PM   #16
ditto on slab-jacking.
is that approximately a 20x15 room? I'm sure the engineer considered load bearing walls and the effect they would have on the upper units-what are the 'rules' when you disturb load bearing walls in a condo? Sounds as if this is a ground floor unit-if it's not a weight bearing issue, has a lightweight addition of grout been considered to bring up the floor?
72chevy4x4 is offline   Reply With Quote
Old 10-03-2009, 08:48 AM   #17
Trade: No
Better prefer skilled manual labour
balacbe11 is offline   Reply With Quote
Old 10-27-2009, 01:05 PM   #18
Manager
Trade: Demolition & Excavation
Concrete floor
How you doing buddy, For this job you should sub it out to a expierenced company dont get caught up in something that will cost you more money than you make email me to discuss some options jovaniverre@aol.com
jovani is offline   Reply With Quote
Old 10-27-2009, 03:05 PM   #19
Had a similar project also, used a good company from Philadelphia, PM me for the name,
Joel
Edsollen is offline   Reply With Quote
Spalling concrete stabilization tsunamicontract Concrete & Paving 4 06-07-2009 07:51 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 08:10 PM
Advice - concrete Pool Deck coping ejleonard Masonry 4 06-17-2008 04:18 PM
