What Paint To Use For Blast Pot?
Old 04-14-2009, 09:37 PM   #1
Greenbuggy's Avatar
Trade: Sandblasting
So this summer I'd like to sandblast my Clemco classic blast pot as its age is definitely starting to show, the paint is faded real bad, some stickers have started flaking off and theres some surface rust around the bottom of the pot and the wheel/stand area. So its a good candidate for some cleaning up.
I'm curious what you guys have used that stands up well to use & abuse. I'm thinking about going with a grey color choice, I thought about POR-15 but I've heard bad things about painting over base POR15 since by itself its sensitive to UV. Thoughts?
Greenbuggy is offline
Old 04-15-2009, 01:01 AM   #2
user20594's Avatar
Re: What Paint To Use For Blast Pot?
Paint over rust? What in the?? I Am in the mood to describe coatings and also sandblasting specs. You. NO1. A clean surface. The rest of the book is put out in the 09' Edition of SSPC Rules and Regs.
user20594 is offline
Old 04-15-2009, 05:14 PM   #3
new path
Blast&Coat's Avatar
Trade: SandBlast & Powdercoat onsite
powder....coat
Blast&Coat is offline
Old 04-16-2009, 09:04 PM   #4
Greenbuggy's Avatar
Trade: Sandblasting
Did you not read the first line of my post?
Old 04-16-2009, 10:29 PM   #5
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
Panderson does that from time to time. You will have to excuse him. As far as a good paint to use. Just use a good epoxy primer and a good equipment enamel. I used to have about a dozen 6 cu. ft. Clemco Blast Pots and I always had the men to paint them up with a Equipment Enamel that was Catalized. I think I got my paint for them at a local automotive paint store that carried it. It's not got to be fancy. It's just a blast pot.
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is offline
Old 04-17-2009, 10:27 PM   #6
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
I used VanSickle from my local Tractor Supply. It is some pretty tough stuff. I blasted the pot, reduced and sprayed. Most Tractor Supply stores sell some good paint. http://www.vansicklepaint.com/tractor/tractorvs.html
killzoneq2 is offline
Old 04-29-2009, 01:58 PM   #7
powder coating mogul
deadjed's Avatar
Trade: media blasting/powder coating
Originally Posted by Blast&Coat View Post
powder....coat
+ 1
Prodigal Son Coating : A Full service powder coating company featuring mobile media blasting , mobile powder coating , along with a 2700 square foot powder coating and media blasting facility located right off I-70 / Oak Grove , MO exit .
prodigalsoncoating.com
deadjed is offline
Old 04-30-2009, 04:12 PM   #8
Greenbuggy's Avatar
Trade: Sandblasting
Originally Posted by deadjed View Post
+ 1
I'd be all about that if it wasn't for the cost. I have a little chicago pnuematic powder coating system but my oven isn't nearly big enough to handle the size of my blast pot
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
Paint Sprayers BiggersJunior Painting & Finish Work 27 01-12-2009 09:49 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
