Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Sandblasting
Old 09-12-2009, 04:22 PM   #1
Trade: Bicycle Powdercoater
What CFM will be needed?
I do not know any airflow formulas and I seriously doubt the relationship between PSI and CFM is linear so I really have no way of figuring this out.
My sandblaster consumes 6CFM @ 125 PSI
My compressor's output is 10.2 @ 90 PSI
Is there a way to find my compressor's 125 PSI output?
Thanks for any help
yakmastermax is offline   Reply With Quote
Old 09-13-2009, 06:31 PM   #2
Glen
Betterblast's Avatar
Trade: Media blasting
Send a message via Yahoo to Betterblast
I wouldn't know either Yak, but it seems to me it doesn't realy matter. You won't hurt anything, the equipment or the bikes, if it goes below 6 cfms. If you run it at 125 psi and you feel it's working for you that's good enough. Knowing the number would't change the outcome. If you feel you need a much higher production rate then it might be time to step up to maybe at least a 100 cfm output and a blast pot to handle it. You could move up to about a 1/4 inch nozle and you would be amazed at the difference. Time is money.
When it has to be clean, Betterblast it!
glenmarcinc@yahoo.com
P-610-323-8084
http://betterblast.com/
Betterblast is offline   Reply With Quote
attorney needed? boman47k Off Topic (Non Trade) 27 04-11-2009 06:11 AM
Needed illeagal aliens floorinstall General Discussion 9 04-02-2009 04:48 PM
Tampa, FL. Concrete Forklift Ramp Needed phattractor Help Wanted or Looking For Work 0 02-10-2009 02:26 PM
Roofers needed in Sea-Tac Deadhead Derek Help Wanted or Looking For Work 0 02-06-2009 11:32 AM
Work needed. Painter/Paperhanger miagregg Help Wanted or Looking For Work 0 02-04-2009 01:01 PM
