#21 |
Trade: Home performance / Log home repair/maintenance
Re: Walnut Shell
Using two different medias will give a different texture, but once stained it is not very noticeable. See if you can find a piece of wood that is the same species and play around with it. My only concern would be that the walnut would add more texture causing it to absorb more stain and therefore causing it to be darker. However, I've done several jobs like this using Sashco's Transformation stain and to my surprise, it did not cause shade variation. As for recycling, to avoid mixing walnut with glass, do everything with the walnut first and then switch over to glass once you are done with the walnut. I agree that sweeping and sifting would be a waste of your time, but if you have a helper that can recycle as you blast, it would save you money in the long run. Of course, there would be nothing wrong with doing the whole house with walnut shells.
| The Following User Says Thank You to Crank For This Useful Post: | Dyer (10-29-2009) |
#22 |
Trade: SandBlasting/Soda Blasting
Re: Walnut Shell
Crank I agree, I have painted house for a long time. If you was to go from a smooth board to ruff than yes it would be bad but if it a slight differance probable not.
as for the windows, they are aluminum, I have had good luck with boat haul tape (for shrink wrap) I may put that on first, then duct tape for extra protaction. PS: Betterblast does the pic of walnut shell that I posted early look like yours? Thanksfor the input everyone
It's one persons stuppid question; that many want to know the answer to. Web Site: www.DyerSodaBlast.com Email: Jim@DyerSodaBlast.com Last edited by Dyer; 10-29-2009 at 04:33 AM. |
#23 |
Glen
Re: Walnut Shell
Here is the nut I got from surface tek. I think it may be a little finer. What do you think?
When it has to be clean, Betterblast it! glenmarcinc@yahoo.com P-610-323-8084 http://betterblast.com/ |
#24 |
Steven Schneider
Trade: Sandblasting
Re: Walnut Shell
The first picture looks like a 20/40 mesh. The second looks more like a 40/60 mesh.
Steven Schneider sschneider@KramerIndustriesOnline.com www.KramerIndustriesOnline.com Right From The Start |
| The Following User Says Thank You to KramerInd For This Useful Post: | Dyer (11-02-2009) |
#25 |
Re: Walnut Shell
Ya Glen I think mine is 20/40 ?
When I did the 57 chevy it ripped out bondo really good but i'm afrade with wood it will rip it hard. a fine would be better. on eco-shell.com it shows the different grades try'd to call yesterday for priceing, waiting for a call back. Thanks for the time and the pic's.
It's one persons stuppid question; that many want to know the answer to. Web Site: www.DyerSodaBlast.com Email: Jim@DyerSodaBlast.com Last edited by Dyer; 10-30-2009 at 05:56 AM. |
| Walnut Chicken Coop | Gus Dering | Carpentry Picture Post | 28 | 03-16-2009 09:55 AM |
| Want to build own home, or have shell built and finish myself, some questions... | Little | Carpentry | 18 | 03-11-2009 10:30 PM |
| American walnut | Dias777 | Flooring | 3 | 01-18-2009 11:14 AM |
| Brazilian Walnut nail down flooring | Monrovi | Flooring | 12 | 01-01-2009 10:13 AM |
| Shell House model | bubbatn | Marketing & Sales | 7 | 12-30-2008 10:19 AM |
