Starting A Monument Business
Old 07-20-2009, 06:00 PM   #1
oonicello's Avatar
Trade: sandblasting
Hello all,
I am about to start a monument company and I am curious if you guys can shed some light on what sandblasting equipment you recommend. What size you think I will need as well as preferred manufacturers.
I will be doing most of the work in a shop, but I will being doing some on-site work as well. Thanks in advance for your replies.
oonicello is offline
Old 07-20-2009, 09:17 PM   #2
user20594's Avatar
Re: Starting A Monument Business
I have done some monument stuff. I think the media you are going to want to you will be aluminum oxide. The grade you need to use will depend on the finished look you are after. I did a huge order of glass frosting is 1999 for Viracon. For a rough look we used grade 54 for a softer frost we use 100 grade. The most important part of the process is getting the right stencil tape. It has to be strong enough so you dont get over blast when cutting is your letters. This is my last day off the road for about a week I will get you my supplier for the tape ASAP. The aluminum oxide can be found on the net you have to find the cheapest supplier in your area. As far as equipment goes find a distributer in your area of one of the big brand names. Schmidt, Clemco, Empire ect. The blast pot should be caplable of adjusting to different pressures. It does not take a huge machine for this type of work. I would still recomend a compressor of atleast 250 cfm just in case you get some customers that want some car frames or other odd jobs done. I like Ingersolrands that have a johndeere in them so they can be repaired at an john deere dealership.
user20594 is offline
Old 07-21-2009, 02:57 PM   #3
oonicello's Avatar
Trade: sandblasting
Thanks Panderson, I really appreciate the reply. I have spoken to a few different mfgs., but I like to get advice from folks who are actually in the field using the equipment. I really appreciate it.
Old 07-24-2009, 09:05 PM   #4
user20594's Avatar
oonecello,
I was rained out today in southeastern MN. I got a chance to look into that tape. U-Line makes packaging and banding components for shipping and banding pallets. Plasti-Blast makes some of the blasting media we use and tapes. Tyco adhesives went broke and a new company now makes the blast tape. Ive been out on the road since march and have not caught up with the suppliers. My local supplier in Austin Mn, Proline distributing may be able to help you with what you need. If I was in the new buisness of monuments I would find out about Wilbet. They make the casts for the caskets. I see thier plants all over the upper mid west. pa I may spelled Willbet or wilbert wrong good luck
Old 07-26-2009, 01:14 PM   #5
oonicello's Avatar
Trade: sandblasting
Thanks again for your input. It has been extremely helpful.
Old 01-04-2016, 01:29 PM   #6
martin1's Avatar
Trade: monuments
Rewards Points: 2
Here's information on a 20 yr old monument company for sale in the Philadelphia, PA area for those of you interested:
http://philadelphia.craigslist.org/bfs/5340449497.html
martin1 is offline
Old 01-05-2016, 06:36 PM   #7
ratherberacin's Avatar
Trade: media blaster
Rewards Points: 270
nevermind
ratherberacin is offline
Old 04-19-2016, 07:19 AM   #8
Steven88's Avatar
Trade: Sandblasting
Hi i am new here can someone please tell me how I can make a post? I have a question to ask about sandblasting thanks
Steven88 is offline
Tags
monument , sandblasting
Starting own business Jimmy0246 General Discussion 3 05-20-2009 12:17 PM
Info on starting business bryank1202 Business 8 09-19-2008 11:32 AM
STARTING BUSINESS (Res. General Contracting) Wildbillcody Business 3 12-20-2006 09:49 PM
Starting out, Looking for business advice dwbrooks Painting & Finish Work 7 11-12-2005 05:16 PM
