Sponge Jet Media And Blast Equipment???
Old 10-25-2009, 09:28 PM   #1
Master Blaster!
BLASTPRO's Avatar
Trade: Sandblasting and Coatings
Ive been checking the net for different blast medias out there and came across a product called Sponge Jet, im sure a few of the veterans out there know what im talking about. Not sure of the cost but I am very impressed with the low or no dust results of the media and the ability to clean fast and to spec. Thoughts anyone, im going to get more info from the company tomorrow.
BLASTPRO is offline
Old 10-25-2009, 09:39 PM   #2
Rick
rlaird's Avatar
Trade: Fire Restoration, Sandblast, Sodablast
Re: Sponge Jet Media And Blast Equipment???
It has its applications,
But if I had to spend the money I'd buy a good blast rig, I had a fellow contractor in the fire restoration business who bought the rig and a classifier,And was offering to sale it to me.
It was close to 30k no compressor included, I can do everything it can do with my blaster and I have more production.I can also get a lot more bang for my buck.
The advantage is low dust and the media is not real heavy of sponge rubber with abrasive glued to it. I tried it out on brick job removing soot, it did ok.the low dust and clean up were great, but the media was more expensive and did not clean as fast as soda.But you can sweepit up and re-use it.
Not trying to dog the equipment, I just like mine better having tried one
rlaird is offline
Old 10-26-2009, 07:00 AM   #3
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
My old employer tried to use the Sponge Blast. (We used to call it Sponge Bobin’)
The problems outweighed the effectiveness of the product.
We would Blast for 1 hour and clean for 5. Recycling it as we went.
They had a machine to dump the media into, shaking it out into 3 sizes. Lots of labor involved.
Although we had lots of problems over several months, the Blasting results on the product was good.
As with any thing it had its ups and downs.
The company abandoned it after a few months.
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Dyer is offline
Old 03-26-2010, 09:27 AM   #4
Sponge Blaster
Enviromediaman's Avatar
Trade: Sponge Blasting
Our company has been using Sponge Media for 3 years now. We wouldn't use anything else. We take 15 mils off of steel and achieve a 2.5 mil profile at the same time. We get 10-15 reclaims out of each lb. They put the following in the Sponge: Steel grit,aluminum oxide, Starblast, plastic, glass, calcium carbonate, etc. With the aluminum oxide, they go from 16 grit to 500 grit. It can achieve 0 - 4.5 mils profile with one system. So the fact that this system has no limitations on what it can be used on, is a great opportunity for blasters. They also have vacuum systems that can be put on the recycler so that the blaster does not have to stop blasting to recycle, it does all the work for you. A school is 200 feet away and the city would not let us use anything else besides Sponge Media because of the low dust.
Hope this helps.....
Enviromediaman is offline
Old 03-26-2010, 08:25 PM   #5
Dyer's Avatar
Although I have tryed it in the "Navy" Setting
I have not tryed it out side.. so for me to say it does not work is a wrong thing for me to say, I did not work right for the Navy contrctors I worked for.
They did not have the proper set up for what they were trying to achieve. with the vac and other type of grit imbeded I think it would have been valubale to them.
Can you show us some pics of projects done?
Cars, Equipment, schools, BOATS, ETC...???
Dyer is offline
Sand Blasting Equipment and Air Compressor For Sale ProStrip Contractor Swap 0 10-21-2009 09:53 PM
Plastic Media, Want your opinions Please! Dyer Sandblasting 7 09-04-2009 08:02 AM
What kind of blast pots are you using? blastoffinc Sandblasting 6 05-24-2009 02:27 AM
12SX Accustrip Blast Pot oshamo Sandblasting 1 04-13-2009 11:35 PM
Thoughts on this equipment? TimberSeal Sandblasting 2 12-14-2008 05:20 AM
