Soda Blasting Cleanup
Old 07-22-2012, 11:29 AM   #1
subsimple's Avatar
I am doing my first fire restoration job and I am considering soda blasting. I am concerned about clean up after the soda blasting is done. It is a four unit apartment building and the fire damage is limited to one of the apartments. The fire damage is in one of the upper units. The unit below it is vacant. What is the usual cleanup procedure? Wet rags maybe? Also, is cleanup necessary on the fire damaged apt since the apt will be gutted at the time of blasting and new walls an flooring will be going in anyways?
subsimple is offline
Old 07-22-2012, 01:07 PM   #2
Veith@toast.net's Avatar
Trade: Painting and wallcover
Rewards Points: 75
Re: Soda Blasting Cleanup
I know the contractor that I do a lot Of painting for has stop using it partly do to clean up. Dry ice or seal sPray is the way to go.
With soda no matter how good you clean it up every one is fighting it till the project is done
David
David Enterprises Inc.
http://davidspaintingandwallpapering.com/
Veith@toast.net is offline
Old 07-23-2012, 06:58 PM   #3
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
Soda is really tough to shoot in a occupied space due to the dust...unless your running a black max fan with some high CFM to keep negative air you'll be apologizing a lot...
www.blastserv.com
blastserv is offline
Old 07-23-2012, 10:31 PM   #4
mbryan's Avatar
Trade: water restoration
Rewards Points: 552
Yes, soda is very messy. It's easy enough to cleanup most of the time. Some sweeping and vacing and that gets most of it. Save it and you can make a smokey cake for the new tenant.
Never used dry ice but the idea of cleaning up water vapor and whatever is blasted off sounds real appealing...
mbryan is offline
Old 07-24-2012, 06:42 AM   #5
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Did a job a while back
Started with soda, switched to fine crushed glass because it was faster
Got to start with low psi, like 40 psi. Then turn it up slowly till it's good for you.
Your gonna need some really good fans.
The space I did was 1200 sqft, one black max fan (3400 cfm) wasn't enough, ended up with two!
Sweep up as you go along, sweep up after, and blow down, sweep up again and repeat. Then run a vac for a while.
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: DyerSodaBlast@gmail.com
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 07-24-2012, 07:54 PM   #6
Todd
blastserv's Avatar
Rewards Points: 762
Jim, curious...did you not buy the biggest black max they offer because of cost or size?...if you were to do it again would you have just bought the biggest one first?
www.blastserv.com
Old 07-25-2012, 05:42 AM   #7
ausisoda's Avatar
Trade: abrassive blasting
Hey dyer with the pressure hold pot how do you get the pneumatic controls to work at 40psi?
Is it as simple as moving the dead man feed line before the regulator?
ABSS supplies.
For a bullet proof blasting machine made in Australia they should be your first choice.
They produce top quality equipment that will give you hours of trouble free blasting.
Their customer service is the best in the business.
ausisoda is offline
Old 07-25-2012, 05:56 AM   #8
Dyer's Avatar
Rewards Points: 864
Yes ausi,
I put on a quick release end on my 12v control solenoid
Keep it plugged in to the regular tap.
When I need to go low psi
I plug in to air source before the regulator.
As I don't do it very often. It keeps the extra lines to a minimum
This way my valves still run on normal air psi....!
Dyer is offline
Old 07-25-2012, 06:03 AM   #9
Dyer's Avatar
Rewards Points: 864
I should have gone with the biggest first..!
But like everyone else, hind site is better than for site.
I was trying to go as big as I could without braking the bank.
My fan runs 3500 cfm though, and is not bad, but on big jobs, 2 would be better.:
I still only have just the 1, I rent a few 2200 cfm fans when I need them from sunbelt. They have the tubular ones that have the flex hose. Great for going out windows from a remote location.
Dyer is offline
The Following User Says Thank You to Dyer For This Useful Post:
blastserv (07-25-2012)
Old 07-28-2012, 08:43 PM   #10
subsimple's Avatar
Wouldn't running fans like that get baking soda all over the neighborhood? There are cars parked on the street right outside where I'd be working.
Old 07-28-2012, 08:49 PM   #11
mbryan's Avatar
Rewards Points: 552
Sub a mobile car wash business for that and add o/p. you will definitely want some type of air movement. Have always had dust carried away with a slight breeze. Wind blows in Colorado sometimes.
mbryan is offline
Old 07-29-2012, 09:45 AM   #12
Todd
blastserv's Avatar
Rewards Points: 762
They make dust socks for the back of the fan to blow the dust into...
www.blastserv.com
Old 07-31-2012, 10:22 AM   #13
wardbo1's Avatar
Trade: fire/water restoration
i have used both dry ice and soda. the clean up on dry ice is a little less than soda , but doen't do as good a job. soda also help in a fire with odor control. good negitive air will control dust from getting into the other app.blast for 15-20 min and then let the air clean up and you should make good time . BUT you will definety have to filter your exhaust air into a sock or you will be washing every car and house in the area.
wardbo1 is offline
Soda Blasting Faster Blaster Marketing & Sales 1 03-20-2012 01:39 PM
Water filter when Soda Blasting?? TRM Sandblasting 2 06-02-2011 02:50 PM
Baking Soda Blasting Pine with clear ECRSS Sandblasting 11 05-02-2011 12:15 AM
Sand Blasting AND Soda Blasting brianterry22 Sandblasting 15 02-28-2011 07:07 PM
Soda Blasting Bizz jma375hh Sandblasting 22 10-18-2009 11:24 AM
