Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Sandblasting
Old 10-07-2009, 04:42 PM   #1
Trade: Sodablasting/ Sandblasting
Schmidt Blast and Reclaim System (BRS)
Has anyone used one? I have a job that they want some Stainless tanks blasted to a uniform finish. This is a multimillion dollar project so they are pretty specific on what they want. They want it blasted, they do not want any dust, and it has to be done next week. I just quoted them $9,000 for 800 sq. ft. that includes blaster($1500), shipping of blaster($1,100), and 750cfm compressor rental($900) and I made the rate 170/hr. which includes media(glass bead), fuel, and consumables. We are figuring about 32/hrs. of blasting @25 sq. ft. an hr. This unit requires no cleanup after and re-uses the media as it goes. Any thought?
blastoffinc is offline   Reply With Quote
Old 10-07-2009, 08:18 PM   #2
Master Blaster!
Trade: Sandblasting and Coatings
Glass bead wouldn't be my first choice in media. Use a media that doesn't break down as much. I have a Schmidt blaster and reclaim, where are you located? thanks.
BLASTPRO is offline   Reply With Quote
Old 10-08-2009, 03:19 PM   #3
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
The glass bead would be good to use on the Stainless Steel. The glass bead will give you a better uniform pattern and it is a round abrasive so the surface will not have a rough profile.
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is offline   Reply With Quote
Old 10-08-2009, 05:37 PM   #4
Master Blaster!
wouldn't the dust from the broken down beads go against what they require?
Old 10-08-2009, 07:23 PM   #5
PRO
panderson2414's Avatar
Trade: industrial coatings, sandlbasting,sodablasting, an
panderson2414
Blastoffinc, What is the update on your job and how did your bid look? Glass beads dont produce very much dust. The peening action they produce does not fracture them
panderson2414 is offline   Reply With Quote
Old 10-09-2009, 07:02 AM   #6
Blastpro, This unit is a portable contained closed-loop system it captures dust as you go. I am located in the Buffalo, NY area.
Panderson2414, I have not yet heard back from them.
Blast Pro Pics and Info BLASTPRO Sandblasting 30 03-18-2009 02:06 PM
