Safety Measures For Cabinet Sandblasting Using Aluminum Oxide - Sandblasting - Contractor Talk
Old 08-09-2008, 12:44 AM   #1
dubCanuck1's Avatar
Trade: Automobile restorer/fabricator
Hello all,
I've recently purchased a cabinet sandblaster and am using aluminum oxide to take the paint of the tubing/pipe I'm using to build manifolds. I've got air and vacuum going to and from the cabinet with the intent to vent the vacuum outside.
I was just wondering if there are any other safety precautions I should take when opening the cabinet. Currently, I'm letting the vacuum run for 30 seconds after I finish a piece before opening the cabinet.
It's 80 grit media. The reason I ask is that I had read about some health concerns with using silica as a media and how it can do damage to the lungs due to its small particle size.
If there is some more precautions, such as a certain type of particle filter to use, I'd sure appreciate it.
Thanks.
dubCanuck1 is offline
Old 08-09-2008, 11:21 AM   #2
ibsocal's Avatar
Trade: Pain
Rewards Points: 160
Re: Safety Measures For Cabinet Sandblasting Using Aluminum Oxide
How big is the box,is the vacuum/dust collector desinged for it.U can ues a half mask respirator with hepa filters, that will keep your lungs working longer.me i just get the parts and close the door no mask.
ibsocal is offline
Old 08-09-2008, 03:38 PM   #3
mwsp's Avatar
Trade: Media Blasting
Most if not all commercial bagged A/O media contains less than 2% free silica.
mwsp is offline
Old 08-13-2008, 03:09 PM   #4
Sandblastdude's Avatar
Trade: Sandblasting
Ya, most blasters honestly don't wear anything but if you want to be extra careful put on a half mask, cartridge style respirator when messing inside the dust collector. And keep doing what you have been doing with regards to the opening of the door. Stop blasting, blow off the item being blasted, let the collector run for a short while, and then open the door.
Sandblastdude is offline
New OSHA standard OsNap Health & Safety 8 01-08-2010 09:19 PM
Construction Safety Coordinators Safety Guy Help Wanted or Looking For Work 0 07-22-2008 08:16 AM
Safety Coordinator needed in north San Diego, CA Safety Guy Help Wanted or Looking For Work 0 02-15-2008 05:22 PM
Safety Inspector Needed in Washington D.C. Safety Guy Help Wanted or Looking For Work 0 12-03-2007 05:11 PM
Dalton, GA Safety Inspector Safety Guy Help Wanted or Looking For Work 0 11-19-2007 04:05 PM
