Piping In The Shop
Old 08-19-2009, 12:52 AM   #1
blastoffinc's Avatar
Trade: Sodablasting/ Sandblasting
Piping In The Shop
I am looking to move my compressor to the other part of our building. There is a interior wall with a 1 car garage size spot beyond that wall(enclosed room with ventilation) I am wondering what you guys think would be the best way to plumb the air. It is about 50' back, then 25' over then through the wall and about 30' to the "compressor room". How about Galvanized pipe? Hose? I will be running my respirator off this line as well. Are there any types of pipe I shouldn't use for breathing air purposes?
I was thinking once I get past the interior wall I would use 1 1/2" pipe with a downward angle with drop-offs for moisture? Any suggestions would be great. I have a 375cfm compressor. The compressor is about 15' in front of the blast pots right now connected with a 25' 1 1/2" hose.
blastoffinc is online now
Old 08-20-2009, 09:56 AM   #2
Re: Piping In The Shop
any suggestions?
Old 08-23-2009, 09:38 PM   #3
Glen
Betterblast's Avatar
Trade: Media blasting
Send a message via Yahoo to Betterblast
I used all copper pipe in my shop. It has never blown out and it's easy to solder together. I have no idea if it could be unsafe to breath air from it. I'm not certain who you ask that question to. I know galvanized metal gives off dangerous fumes if you weld with it. I think pvc would hold up and is probably inert.
Betterblast is offline
Old 08-23-2009, 09:53 PM   #4
ausisoda's Avatar
Trade: abrassive blasting
I think copper would be a bad idea as it will go green on the inside and i dont think that **** would be good to breath wouldnt stainless steal be cheaper
ausisoda is offline
Old 08-27-2009, 06:24 AM   #5
Glen
I guess thats right about the copper. I never bought stainless so I don't know about price. What I liked about copper was I could easily possition a connector and solder it. I had trouble with black steel before that when I screwed it tiogether tight, the connection was faceing the wall. But I don't have to breath that air. I have seen flexible plastic in homes for air ducts. If it can take the preasure it might be a good idea and cheap.
Old 08-27-2009, 10:43 AM   #6
Railman's Avatar
Trade: Railing
Use black pipe. Run the line downhill (from source) with pipe saddle hangers found at any decent plumbing supply. There is a ceiling bracket, all thread drop, & saddle fitting. It's cheap, easy, & flexable. Put plenty of t's on the lines, so as to allow later line additions. Use a t's instead of coupler fittings, with a plug in extra hole. Using t's is cheap insurance over the cost of a coupler, & the risk of having to tear apart later to add a run. Put condensate filter at end of runs, prior to coupler outlets, at a height that's reasonable to get to. This is the industry standard for shop air lines. It's cheap, & it works.
Galvanized pipe is only galvanized on the outside, which simply doesn't help anything. Copper works, but is very expensive these days. Black pipe will last a life time, which is probably long enough for most of us.
Joe
Railman is offline
Want a tablet pc for the shop area StairJunkie Technology 16 06-01-2009 10:38 PM
Super Cheap Shop Gear basswood Finish Carpentry 22 02-25-2009 09:42 PM
Setting up the shop Jason Whipple Carpentry 53 01-25-2009 10:10 PM
shop vac recommendations? downwithfloors Flooring 18 12-12-2008 11:25 AM
Leasing a shop CatAlii Business 7 08-04-2008 12:29 AM
