Pictures Of My Equipment
Old 09-23-2007, 04:47 PM   #1
Tony
BulldogMedia's Avatar
Trade: Media Blasting and Powder Coating
Here are some pictures of my setup as of now.
Pictures of my equipment-100_0533.jpg   Pictures of my equipment-100_0534.jpg   Pictures of my equipment-100_0535.jpg
www.bulldogblasting.com
BulldogMedia is offline
Old 09-23-2007, 04:58 PM   #2
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Re: Pictures Of My Equipment
Rig looks good, but are you getting ready to powder coat the Lexus in the driveway
LNG24 is offline
Old 09-23-2007, 07:29 PM   #3
tgeb's Avatar
If you hit the brakes real hard does that thingy in the back of the truck bounce off the cab, or just break the rear window? I would add another tie down on that rascal.
But seriously, that is a nice set up.
www.gebcon.com
tgeb is online now
Old 09-23-2007, 07:31 PM   #4
joasis's Avatar
Just curious, but what is the CFM of the outfit you are using? I have an 85 Schramm compressor and would like to have a pot like that one.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
Old 09-23-2007, 07:43 PM   #5
Tony
Never has to hit brakes hard yet, maybe I should put another strap to the back.
Old 09-23-2007, 07:47 PM   #6
Tony
185 CFM compressor for the # 5 nozzle that I run.
Old 09-23-2007, 10:50 PM   #7
General Contracting
LNG24's Avatar
Yeah, I would strap it back. Always best to have a 4 point tie down, but looks like three will be ok here. You can also add a headache rack.
LNG24 is offline
Old 09-28-2007, 07:29 PM   #8
plazaman's Avatar
Nice, any moisture problems ?
plazaman is offline
Old 09-28-2007, 08:59 PM   #9
Tony
Plazaman I have not had any moisture problems at all with this setup.
Old 09-28-2007, 10:33 PM   #10
MFWIC
Tmrrptr's Avatar
Trade: house painter
OK, I'll admit I know little about production sandblasting, but the capacity of your pot looks small, to me.
Am I wrong?
r
Tmrrptr is offline
Old 09-28-2007, 10:48 PM   #11
plazaman's Avatar
How long do you blast for? Around what temp and humidity?
Ive attempted a Soda Job this monday, everything started off well. After lunch, i noticed production slowed down. After opening the nozzle, i found the soda to be wet.
I am using a Water induction nozzle, (WIN 4) . Does water ever mixes with baking soda in the nozzle?
Tmr- his pot is small , but when shooting soda, tiny particles 260 microns, it should give you decent blasting time between fills , it also depends on your metering. Monday was my 2nd attempted soda job but my 1st job where we could actually blast for 1+ hour. I was amazed how far 1 bag went. I was under the impression that 1 bag would last 15 mins, not in this case.
I have a 3.5 cu pot, which is huge. When filled, i guess i could blast at least 2.5 hours without filling with my current metering postion.
Ive blasted coal slag a few months ago, the particles are much larger compared to 260 micron baking soda, that i had to fill about every 15 mins. In those cases, you wished you had a larger pot.
plazaman is offline
Old 09-29-2007, 10:42 AM   #12
Tony
Am I wrong?
r
Will the nice thing is I can move the pot around and get to out of the way areas. With a full pot I can blast for about a hour between refills and at that point i am ready for a little break.
Old 09-29-2007, 10:49 AM   #13
Tony
Plazaman I have blasted 8 hours with it this summer in the high 90s and high humidity, That was with glass and all the traps opened a little. I have use soda for a hour in the same weather and have not had any problems.
Old 09-29-2007, 08:22 PM   #14
plazaman's Avatar
how many cfms is your compressor?
plazaman is offline
Old 09-29-2007, 09:17 PM   #15
Tony
Plazaman the compressor I use is a 185 CFM
Old 09-29-2007, 09:24 PM   #16
plazaman's Avatar
im using a 210
plazaman is offline
Old 03-16-2009, 08:34 PM   #17
aussie learner's Avatar
Trade: soda blasting
does anyone have detailed drawings including part names and brands for a soda blasting pot assembly
aussie learner is offline
Old 03-16-2009, 09:04 PM   #18
new path
Blast&Coat's Avatar
Trade: SandBlast & Powdercoat onsite
www.surfacetekinc.com worth every penny for the reliability it has given us.
Blast&Coat is offline
Old 03-16-2009, 09:25 PM   #19
CO2Solutions's Avatar
Trade: Dry Ice Blasting
I was going to add the 'Canadian' version of the www.surfacetekinc.com unit - it's the exact same blaster, just a different name from a different distributor. I've demo'd the unit and thought it was great...
CO2Solutions is offline
Has anyone used PROBLAST equipment. jeryst Tools & Equipment 17 12-03-2011 09:53 AM
Antique Equipment Debookkeeper Tools & Equipment 19 09-08-2009 08:14 PM
Used equipment... mattbatson Excavation & Site Work 18 10-06-2007 06:48 PM
Equipment Show denick Excavation & Site Work 6 07-19-2007 07:48 PM
Help - I need some advice from equipment operators. ann2255417 Excavation & Site Work 22 02-28-2006 07:19 PM
