Nozzle Size Question.
Old 03-05-2010, 10:54 PM   #1
Glen
Betterblast's Avatar
Trade: Media blasting
Send a message via Yahoo to Betterblast
If I go down a size from a 5 to a 4 for blasting soda will I save on usage or just get less work done for the extra hang time I might get?
When it has to be clean, Betterblast it!
glenmarcinc@yahoo.com
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 03-06-2010, 06:53 AM   #2
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Re: Nozzle Size Question.
Glen, I just try'd this two days ago on a boat, With Soda...
Tried 4, 5, 7, 8
4 worked good for a smaller jobs, compressor didn't barly kick up, thought it was a little slow. (but was doing a large area)
5 was also good, better than 4 but still a bit slow.
7 seemed to give the best psi, patteren and time.
8 was wasting grit, psi drop, compressor running on high end.
Could be different on a car or other project.
I have a nozzle from a cabnet blast gun. sized it up to fit hose. this works good for really small areas or detail blasting (Pencel Blasting)
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Dyer is offline
Old 03-06-2010, 06:23 PM   #3
Glen
I figured an 8 would be too much but I did get a 7. I think I'll try the next boat one side with a 5 and empty the pot and refill to do the side with the seven and make sure to check the time and lbs. It'l be interesting to see the difference.
P-610-323-8084
Old 03-06-2010, 06:29 PM   #4
Dyer's Avatar
Glen, I'm running a 185 at 100psi
if your compressor is bigger than an 8 might do fine.
Dyer is offline
Trailer size activepainter Vehicles 27 12-26-2009 10:24 AM
Question on stairs. billy d Decks & Fencing 59 11-12-2009 08:01 PM
Print a PDF file in actual size ProWallGuy Technology 6 04-15-2009 12:58 AM
Improper Header Size greg24k Framing 9 03-27-2009 08:18 PM
Sewer Infrastructure Question ABLE1 Excavation & Site Work 20 05-28-2008 11:05 AM
