Tony
Trade: Media Blasting and Powder Coating
New Here
Hi, i just found this site today and seem like a good source for info. I have just started a blasting(soda, superK, churshed glass, etc) and powder coating business. I was curious as to how you all charge for your blasting services, per hour, per sq feet or other? Also is there source to see what rate to charge in a area?
Thanks for any help Tony
www.bulldogblasting.com |
#2 | |
Re: New HereQuote:
I am in the same boat as you, just started blasting. Pricing is dependent on conditions, requirements (containment, disposal) overhead etc.. I would first figure out the basics, whats your overhead, how much do you need to make per day. Any pics/info on your setup? Thanks Rich |
Tony
Re: New Here
Sullair 185 air compressor, 250cfm after cooler, 400 cfm water separator and surfacetek st1650 blasting pot. I will get some pictures and post
Chris
Trade: SANDBLASTING
Re: New Here
Will someone please explain what these after coolers are and why you need them? Is this simething I might need using slag?
#5 | |
Re: New HereQuote:
Kill Compressed Air contains moisture. The moisture is in the air stream. IF too much moisture in the air, you can have media flow problems. In most cases, you should have a particle/water filter installed on your pot. When shooting water soluable media such as soda, moisture can cause the soda to clump up at the nozzle, especially on really hot days. The aftercooler cools the air & removes the moisture before the air reaches the blast pot. Ive blasted slag without the aftercooler setup, you should be fine. You really dont need an aftercooler if you are shooting regular stuff. At most, install a water separator at your service valve. Below is a pic of my aftercooler setup |
Tony
Re: New Here
That is what my after cooler look like also, I use soda, superK and crushed glass and if any of them get wet they clog. I also have two water separators on the pot.
#7 | |
Re: New HereQuote:
Hey, off topic, but, do you have any experience with blasting painted red bricks? |
Tony
Re: New Here
I have not done any, but I have talked to my supplier which has done large jobs with crushed glass.
#9 | |
Re: New HereQuote:
might be an option, but cleanup might be a pain |
Tony
Re: New Here
Yes all cleanup is a pain but bid it high and give the customer the option of doing the cleanup them self.
Re: New Here
what other projects have you blasted?
Tony
Re: New Here
car parts, boat parts, wheels, trailers(boat, car, horse), rod iron railing, steel steps, cars, warehouse floor.
Remember I am just starting here and the word is starting to get around
Trade: Soda Blasting-paint stripping & surface cleaning
Re: New Here
Plazaman- I have blasted brick both interior and exterior with SODA. The customer was very happy with the interior work, white painted red brick with very fragile morter joints. The Morter was made with crushed oyster shells in the 1700's. The exterior brick was painted yellow over white, and blasting would have worked if the home/brick was not close to 300 years old.
Test spots helped the customer decide the paint was OK, compaired to stripping the exterior by hand on a 3 story home.
http://www.galeforcesodablasting.com/ |
