Old 01-26-2010, 10:25 PM   #1
blast4cash's Avatar
Trade: media blasting
another new guy bin looking for a bit alot of good advice here so i signed up
blast4cash is online now
Old 01-26-2010, 10:27 PM   #2
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Re: New Guy
welcome to the site Blast!
~Matt
BreyerConstruct is offline
Old 01-26-2010, 11:08 PM   #3
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
Re: New Guy
Welcome, how long have you been blasting and what is your set up?
killzoneq2 is offline
Old 01-26-2010, 11:09 PM   #4
"Pro"
Ayerzee's Avatar
Trade: Construction Engineering Student
Send a message via AIM to Ayerzee
Re: New Guy
Welcome to CT!
Dan
Ayerzee is offline
Old 01-26-2010, 11:15 PM   #5
blast4cash's Avatar
Re: New Guy
did some afew years back for a classic tractor guy. just bought 72nova454 out. sory to the guys also looking at it nice stuff
Old 01-26-2010, 11:23 PM   #6
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
Re: New Guy
Im not sure who 72nova454 is or what he had for sale.
Old 01-27-2010, 12:02 AM   #7
joel383's Avatar
Trade: Soon to be Soda Blasting, Satellite Communications
Send a message via Yahoo to joel383
Re: New Guy
that was some good stuff. probably would have done it my self if i had cash in hand! good luck, your one up on me, i have yet to purchase a rig yet.
Kill... look for the thread entitled, Complete mobile blasting set-up for sale CHEAP!
"schmidt Accustrip 11SX soda pot with 50' of blast hose, a Marco 3 cu. ft. pot with 50' of blast hose, #4 nozzles on each, a 2005 Ingersoll Rand Air Source Plus mobile compressor 185SCFM @ 100PSI(427 hours on it), Apollo #24001 600HP blast hood & cape(NEW), #4410 Cool-tube w/belt(NEW), Clemco CPF20 Particulate filter w/regulator(NEW), 50' of 3/8" respirator hose(NEW) & a Marco moisture seperato(NEW)... (42) 50 lb. bags of Natrium Soda & (20) 100 lb. bags of Marco #3060..."
"Take time to deliberate, but when the time for action has arrived, stop thinking and go in." -Napoleon
JGW Enterprises Cleveland, Tx
joel383 is offline
Old 01-27-2010, 06:11 AM   #8
Glen
Betterblast's Avatar
Trade: Media blasting
Send a message via Yahoo to Betterblast
Re: New Guy
Breyer, I'm in Pottstown. If you ever need a bag of soda on short notice or anything stop by.
When it has to be clean, Betterblast it!
glenmarcinc@yahoo.com
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 01-27-2010, 06:33 AM   #9
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Re: New Guy
Welcome Mr. Cash!
Good guys on here, lots to learn and share.
Nova sounded like he had some good equipment. hope all goes well for you.
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Dyer is offline
Old 01-27-2010, 08:22 AM   #10
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
Re: New Guy
Wow, I did see that.. He got a lot of good stuff...
Old 02-01-2010, 01:36 PM   #11
blast4cash's Avatar
Re: New Guy
Got my first pay job to do today. Only 4 truck rims but a good job to test out my new equipment.
Old 02-01-2010, 08:54 PM   #12
Dyer's Avatar
Re: New Guy
Dyer is offline
Old 02-02-2010, 10:17 PM   #13
blast4cash's Avatar
Re: New Guy
Set up ran good took about 40 min to blast. Also did a 1000 gal propane tank. Turned out nice.
Old 02-02-2010, 10:29 PM   #14
blast4cash's Avatar
Re: New Guy
Maybe a dumb question but never ran a pot w/choke valve before what is the purpose?
Old 02-03-2010, 06:30 AM   #15
Glen
Re: New Guy
Cash did you show us a picture of your set up? A chock valve is most likely a ball valve like what is used on regular air and water supplies. On your pot it would serve to limit the amount of media flow to match the psi, cfm and type of media inoder to get the most efficient blast. You will just have to adjust it now and then to learn what works for you. Because it works by a hollow steel blall being turned escew which limits the size opening inside the valve it may wear out in a short time. You may want to have another on hand for quick repairs.
Eccept for some soda only pots, the commercial pots we all use have much more advanced mixing systems on them that allow a more sensitive adjustment with less wear. From the type of valve it sounds like you may be using a pot designed for a do it your selfer, which is fine, I started with a small Harbor Frieght set up before I knew anythiing. But if you are not yet working with a larger cfm unit you will be truely amazed at the difference when you move up.
P-610-323-8084
Old 02-03-2010, 08:14 AM   #16
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
Re: New Guy
A Choke valve is used to clear a clog in the blast pot. It shuts off the air pressure going straight to the blast hose and directs all pressure to the pot chamber to push the clog out. When there is a clog you turn the valve in the OFF position while the pot is running and then turn back on after about two to three seconds. This should push a small clog right on thru. During pot operation this valve is always run in the fully open position. This valve would be a Ball Valve as well.
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is offline
Old 02-03-2010, 01:43 PM   #17
blast4cash's Avatar
Re: New Guy
Thanks Benny all the pots I have run in the past just had a single line to bottom no valve. If it cloged we shut down and took it apart to clean it. Man this new stuf is nice.
