Help With Estimating Amt. Of Media
Old 05-16-2008, 08:39 PM   #1
sctshf's Avatar
Question
I am new to sandblasting and need to put a quote in to paint silos. Of course they need blasted first and i can't find anything on how to estimate the amt. of media needed. The sq. ft. of the silos is roughly 40,000 which includes the framing, ladders, catwalks, etc. If anyone can help me it would be appreciated.
sctshf is offline
Old 05-16-2008, 08:40 PM   #2
genecarp's Avatar
Re: Help With Estimating Amt. Of Media
hello, welcome to the site
genecarp is offline
Old 05-16-2008, 08:42 PM   #3
sctshf's Avatar
Thank you very much
sctshf is offline
Old 05-16-2008, 09:01 PM   #4
Tony
BulldogMedia's Avatar
Trade: Media Blasting and Powder Coating
you really need to do a test blast in a couple different places on the silos to see how many sq ft you can do in a minute. You should know how much media you pot uses in a hour. From that you should be able to come up with the time and media needed.
www.bulldogblasting.com
BulldogMedia is offline
Old 05-16-2008, 09:01 PM   #5
plazaman's Avatar
Wow! Huge Project, 40,000 Sq.ft really depends on how many layers of paint. Id figure 1lbs-1.5lbs for every sq.ft 40-60k lbs could be more, could be less, but id keep those numbers for quoting. If you do win the bid, I wouldnt purchase all the media at once. I would purchase some and watch how it goes from there. What kind of equipment are you using? Any Containment?
plazaman is offline
Old 05-16-2008, 09:09 PM   #6
sctshf's Avatar
I tseems to be only two coats of paint. I got some prices on rental equip. that holds 300#. Other than I don't have the the exact name of the equip. Do you suggest any in particular?
sctshf is offline
Old 05-16-2008, 09:33 PM   #7
Tony
also to what sp or nace level does the blast need to be? that will also determine how much media you will need
Old 05-16-2008, 09:56 PM   #8
plazaman's Avatar
what size compressor do you plan to run? that might determine pot sizing also. does the project call for containment? the areas you blast, you might want to prime the same day also, so maybe figure half day for blast and next half for prime.
plazaman is offline
Old 05-17-2008, 08:55 PM   #9
gran_national's Avatar
Trade: Sandbalsting
sctshf, you're right up the road from me. How's this sound. If you buy me the equipment, I'll blast it for you for just the cost of materials. Although, I don't know enough about pricing to know if that'd be good or not for both of us as I'm just kicking around getting into it as well.
gran_national is offline
Old 05-29-2008, 10:57 PM   #10
user20594's Avatar
forty thousand sq. ft. at 3.46 for an zinc epoxy urethane. you get back to me. that is a good price
user20594 is offline
Old 05-29-2008, 10:59 PM   #11
user20594's Avatar
dirext talk to bull dog media how is it going for you
Old 05-29-2008, 11:15 PM   #12
user20594's Avatar
bismark, I have A job I cant get to this year it is Ulen. three half mills. go for it at 2.30 get after it. If you dont I will do it in the next yaer
Old 05-29-2008, 11:31 PM   #13
user20594's Avatar
I dont run pounds per squre foot. I run abrasive by the pot, one pot that has 20/40 in it should run 45 mins. that is in a schmidt 650. I run small pots with enough air to them that at the nozzle they produce 135 psi that psi is enough to produce a white blasted surface on most kinds of steel. I have been a big pusher of the super stick. For my kind of work it is great . how about you? I blast paint and big steel. then coat it. I use tnemec what do you use.
Old 05-30-2008, 03:26 AM   #14
MEDIA GUY
MEDIA MAN's Avatar
Trade: ABRASIVE MEDIA BLASTING; SANDBLASTING
Post again with more info please. Who's the contact person? Not certain where job is located. What type of coating? etc.
MEDIA MAN is offline
Old 05-30-2008, 11:59 PM   #15
user20594's Avatar
the job is in Ulen . you have to get it done I will get this job if you dont. the guys that can are not far from you. Im the guy that is the guy that will get it done, Im three hundered miles away
Old 05-31-2008, 12:05 AM   #16
user20594's Avatar
look up the coop in the area. i cannot give you my tank builders thats up to you
Old 06-01-2008, 11:34 PM   #17
user20594's Avatar
this is for bismark. I was in your area a couple of months ago I may have talked to you on other threads but here is the skinny. Triangle ag is a new coop that formed 20 mins north of fargo. they had another name. The job is in ulen mn. It was built by my tank company. there are three half million gallon tanks. There are also tanks that are in primer that will need over coating. use a coating that will not bubble the existing coating. I dont own the tank company Im a sub contractor for thier Iowa and wisconsin div.
Old 06-01-2008, 11:36 PM   #18
user20594's Avatar
look up triagle ag
Old 06-02-2008, 10:09 AM   #19
Trade: Sandbalsting
I'm really trying to understand what he's talking about, but I don't at all! Not that is my business, but I can't really make sense of most of panderson's posts.
Old 06-04-2008, 01:54 AM   #20
MEDIA GUY
MEDIA MAN's Avatar
Got it! Thanks for the heads up. I'll see what I can do.
Pricing, Estimating, and Success Brian Business 515 Today 04:46 PM
Estimating help Sparky General Discussion 16 04-10-2011 08:12 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Anyone Make Their Own Excell Spreadsheets for Estimating? TurnkeyConst Technology 1 03-17-2007 11:49 PM
Estimating Article Series hatchet Business 15 07-15-2004 12:47 PM
