Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Sandblasting
Old 08-16-2009, 05:05 AM   #1
Trade: abrassive blasting
Grit sizes wtf
I Just tried to order some more fine crushed glass today and i couldnt get the type i allways get the new place said that the finest they had was 30/15 that sounds course grade to me but the grading they use went 30/15fine 0.85 medium and 1.5 course can some body explain these sizes to me how fine is 30/15 im confused im still kind of new to this stuff. i just asked for fine crushed glass before and thats what i got.
ausisoda is offline   Reply With Quote
Old 08-16-2009, 09:47 PM   #2
haha
I worked it out far out they need a standard system to class abrasives its 30/15 microns which is fine grade
Old 08-17-2009, 01:03 AM   #3
Trade: sodablasting
Got my samples from colmax today 0.8mm - 0.3mm size looks to be the go, also got a samlpe of under <0.3mm but it looks too fine just like powder, can not wait to try it
Idontknow is offline   Reply With Quote
Old 08-17-2009, 01:46 AM   #4
haha
They sent you 3 little white pails i got mine today also the 0.3/0.8 looks good there is a guy i use now that is a bit more switched on he has 3 grades 30/15 for general coating removal 0.85 for medium work and 1.5 course grade his stuff is good its $185 per one and a half ton ive ordered some 0.85 and some 30/15 his stuff is supposed to be better graded then the colmax stuff i called imperial blasting in nsw and thats the gear they are using 30/15 for paint removal and 0.85 for underbody paint and deadner removal
Old 08-17-2009, 01:59 AM   #5
forgot to add here is his number 0409215680 his name is mark and he works for wsn challora recycling
Old 08-17-2009, 03:03 AM   #6
Trade: sodablasting
The 0.3 - 0.8 stuff is that the same size as what you were using?
Old 08-17-2009, 04:15 AM   #7
Yea that glass was about the same the other number i gave you is the guy that has the best burwells abrasives used to stock some stuff that was sometimes a bit **** it had paper and was dirty and if you let it sit it would smell funny i think that was colmax glass but it apears from the samples that they have cleaned up there act a fair bit i used my last lot of burwells and they dont stock the finer grades any more so thats why im checking suppliers but after calling around a few of the top auto blasters like imperial blasting this guys number kept on popping up so i went with his glass give him a call and tell him simons sodablasting gave you his number he will sought you out and at $181 PER 1.5 TON its a bloody good price.
The 30/15 he stocks is a little finer graded (so everybody tells me)and would leave a smother profile then the 0.3/0.8
Have you got an after cooler yet?
Old 08-17-2009, 04:47 AM   #8
Trade: sodablasting
No aftercooler yet, got a boat to do tomorrow (with soda) I'm not sure if the ASB media valve will take the glass, I don't know what steel is inside them ? glass might grind it away, it's pointless asking them, they will only tell me to use soda through the valve, ABS has more secrets then the CIA
Old 08-17-2009, 05:22 AM   #9
yea them blokes are like that if you read there website carefully they do say they that you can put other media through there pots but then they have a big write up on why would you want to so you would be covered by a warranty if it did chew it out it would have to be made from some weak **** not to stand up to glass.
Have you blasted the gel coat on a boat before?
What size nozzle do you use?
Old 08-17-2009, 05:42 AM   #10
Trade: sodablasting
Yer, done a couple of boats, I have been using a #4 nozzle @100psi but tomorrow I will try the #5 @ 90psi (due to air requirements) and I will turn up the media up a bit, have to get this one done as quick as possible.
Because ASB only recommend using soda through their gear they only use a mild steel nozzle's not tungsten or any thing like that, but I will still run some glass through it to try it out
Old 08-18-2009, 03:46 AM   #11
Your kidding me there nozzles are only mild steel thats a bloody joke take the machine back mate they state on there web site that they can blast other medias through there gear if i were you i would ask for a refund if they dont threaten to take them to the ACCC because the equipment doesnt do as advertised.
European Sheet Goods Sizes ScenicArtist General Discussion 9 02-17-2009 07:56 PM
Sanding Walls with 80 Grit Paper on Orbital Questions plazaman Painting & Finish Work 5 12-19-2008 04:01 PM
hole sizes framerman Electrical 34 12-09-2007 09:51 PM
What grit sandpapers for different jobs???? Sellncars Finish Carpentry 5 08-09-2006 11:28 PM
Real Room Sizes MikeT Construction 3 07-12-2006 08:19 PM
