Tony
Trade: Media Blasting and Powder Coating
Dust Removal From Inside
How do you guys remove dust from inside caused by blasting? Fans with ducting or some way else? If you are using fans what kind?
www.bulldogblasting.com |
Chris
Trade: SANDBLASTING
Re: Dust Removal From Inside
Bulldog, I have not done much indoor blasting accept for at my own place. I have read a few places that if you are doing a fireplace, that you plastic off a small room around the fire place, put a shop vac in the space with you that has a filter bag, run an exhaust hose under the plastic, turn it on when you blast. I have never tried it so I cant say how it works. I used one of those big fans that you get at Lowes 54".
I see you are in Coumbus Ohio, I am in near Richmond Indiana just off of I-70 on the Ohio border. They make large water vapor dust traps that pull 300 cfm that can be hooked into any building ducting or be pulled up right to the front door. I saw one that a guy made, it had several chambers with several large curtins in it that you run the dust into and it turns it into nasty muck. |
Re: Dust Removal From Inside |
I use a high velocity grain dryer fan. Put a paint boothe sock on it and change it for every one hour soda blasting, every two hours of glass and every four hours for coal slag. It works for my small jobs but it will not work for big jobs when you have a safety officer or osha involved
Tony
I am looking for a used indoor dust collector now. Trying to find one that I can afford at this time.
what do you need
| Wallpaper Removal | Red Canary | Painting & Finish Work | 33 | 03-21-2007 03:24 PM |
| Plaster Removal | Mulecreek | Drywall | 8 | 01-16-2007 10:13 AM |
| pricing wallpaper removal | lornmastro | Painting & Finish Work | 23 | 09-21-2006 09:40 PM |
| Dust everywhere...Can I start painting? | atari | Painting & Finish Work | 4 | 06-14-2006 12:18 AM |
| Question about inside corners | Lone Wrencher | Drywall | 36 | 12-08-2005 07:37 PM |
