Compressor Keeps Blowing Nylon Tube...
Old 05-17-2015, 04:32 PM   #1
Motivated Noob
BarrierIslands's Avatar
Trade: Abrasive Blasting
Rewards Points: 148
My Sullair 185 has been blowing a nylon tube between the siphon tube on top of the sump and the bottom end of the compressor. It's happening more frequently now and every time it happens, it's in the same spot. What could be causing this?
Barrier Islands Blasting LLC: Charleston, South Carolina
www.barrierislandsblasting.com
www.facebook.com/barrierislandsblasting
BarrierIslands is offline
Old 05-17-2015, 07:17 PM   #2
Blast Off's Avatar
Trade: Media Blasting
Rewards Points: 275
Re: Compressor Keeps Blowing Nylon Tube...
Where on the tube is it blowing out? Could an exhaust leak be pointing at the tube? Does the tube pass near a heat source or a sharp edge?
"Hokey religions and ancient weapons are no match for a good blaster at your side kid."
Blast Off is offline
Old 05-17-2015, 08:47 PM   #3
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 862
Is your tube rated for the heat of the tank, the tank can run up to 190 deg.+
or is it rated for the psi. (Not sure of the psi it runs)
Dyer is offline
Old 05-17-2015, 08:49 PM   #4
Dyer's Avatar
Rewards Points: 862
Check to see if it's chafing on a part or other things like exhaust to close or its near the screw housing etc...
Dyer is offline
Old 05-17-2015, 08:51 PM   #5
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
The nylon tube that is on the bottom of your element (screw) and runs to the top of your separator is the scavenge line. It is constantly sucking the oil out of the element and putting it back in the separator. My guess would be weak rating on tube or bad install.
www.blastserv.com
blastserv is offline
Old 05-18-2015, 02:49 PM   #6
Motivated Noob
Rewards Points: 148
I got a tube rated for higher psi/temperature today. Going to go try it out in a little bit. Also, I believe that my engine idle speed and compressor pressure screw aren't set correctly. Does anyone know how to sync these two things up on a Sullair 185?
Old 07-10-2015, 02:14 PM   #7
Elitembs's Avatar
Trade: Media blasting
Rewards Points: 12
Mine just blew for the first time last week any help would be appreciated.
Elitembs is offline
Old 07-10-2015, 02:20 PM   #8
GettingBy's Avatar
Rewards Points: 6,486
To gather clues you could reinforce the tube in that area by using strong cord and a
https://en.wikipedia.org/wiki/Whipping_knot
And most materials act differently for a steady stress vs. a periodic impact stress. The impact load may be within normal stress limits.
GettingBy is offline
Old 07-10-2015, 03:08 PM   #9
Motivated Noob
Rewards Points: 148
I was an idiot and my tubing wasn't rated for the correct PSI.
Old 07-10-2015, 03:15 PM   #10
GettingBy's Avatar
idiot/ˈidēət/
noun
a stupid person.
That is a probably a pessimistic interpretation of what happened.
A mistake is not the same as a blunder.
And I think your Family of Origin used that word a lot. Too bad it stuck.
Old 07-10-2015, 03:22 PM   #11
Elitembs's Avatar
Rewards Points: 12
This was factory tube and the unit only has 187 hours.
Elitembs is offline
Old 07-10-2015, 06:40 PM   #12
GettingBy's Avatar
Design defect?
At these many hours, could it be infant mortality?
https://en.wikipedia.org/wiki/Bathtub_curve
Random bad part, bad luck?
Factory damaged the tube?
Depending on how you value your time I'd repair it before ordering a new part.
Old 07-20-2015, 08:41 PM   #13
Dyer's Avatar
Rewards Points: 862
Know how ya feel.
Compressor keeps blowing nylon tube...-fb_img_1437439037538_1437439266918.jpg
Dyer is offline
Old 07-29-2015, 07:29 PM   #14
Dyer's Avatar
Rewards Points: 862
I blew a fan belt, and unit overheated...
fixed that but then it started blowing oil out the air end... Ya
so after changing all filters and checking lines. I check the scavenging tube, it has a little check valve that is no bigger then the line, just a spring and small washer with a pin hole in it. It was plugged up with a small piece of hair from the filter,
took that out, cleaned it, and have had no problems since then!
yep that's my day
Done one week waiting on back ordered filters...
Dyer is offline
Old 07-29-2015, 07:38 PM   #15
GettingBy's Avatar
Do they sell factory manuals with troubleshooting flowcharts for these things to consumers?
VCR manuals are $50, Stihl wouldn't sell me a manual for their leafblower and some vehicle manuals are $400 and you mostly can't use them.
Old 08-02-2015, 07:23 AM   #16
Dyer's Avatar
Rewards Points: 862
I do have sll the books for my IR
but nothing in it for what was wrong. ...
even called the IR dealer. And guess what.
They didn't know to check that either lol
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Newly installed deck blowing like a horn with the wind geospec Carpentry 6 08-07-2017 07:06 PM
Occidental Leather vs. Occidental Nylon AJ_Lonestar Tools & Equipment 12 09-02-2013 01:32 PM
A good 12 minute watch. (you tube) kookoomouse General Discussion 29 05-22-2013 07:02 AM
Classic Electric NJ is now on You Tube Magnettica Marketing & Sales 21 01-28-2010 03:56 PM
Improvised Funnel from Caulk Tube basswood General Discussion 10 11-29-2009 11:12 PM
