Blasting Sheet Metal Off Old Farmall
Old 09-19-2008, 01:53 AM   #1
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
Going to be blasting some sheet metal off of an old farmall tractor. I know to drop the pressure down and stand back. Any other tips to stop warping?
killzoneq2 is offline
Old 09-19-2008, 11:06 AM   #2
ibsocal's Avatar
Trade: Pain
Re: Blasting Sheet Metal Off Old Farmall
If I was going to do another vehicle or any sheet metal that is in need of restoration/preservation I would start with a strong paint remover that you can brush or roll on.let it work it's magic.pressure wash or scrape/wipe off old bubbled coatings and then a light blast if it still needs it.
ibsocal is offline
Old 09-19-2008, 12:22 PM   #3
Tony
BulldogMedia's Avatar
Trade: Media Blasting and Powder Coating
Kill, you got it turn down the pressure and back off some. make sure you do not stay in one spot long and keep the nozzle at 45 degree angle to the metal.
www.bulldogblasting.com
BulldogMedia is offline
Old 09-19-2008, 05:15 PM   #4
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
He dropped off all the parts today, will be blasting Monday or Tuesday. Thanks for the input...It is not as thin as I thought it would be, I should be ok.
Old 09-19-2008, 06:45 PM   #5
plazaman's Avatar
what media are you using?
plazaman is offline
Old 09-19-2008, 08:24 PM   #6
joeslob's Avatar
Trade: Renovations
I did a Farmall A last year. I used left-over aluminum-oxide (54G) at around 45 PSI. Like you said the metal is pretty thick, so I wasn't too worried about warping. The only problem I ran into was blasting the oil pan. I did a quick pass over, and punctured a hole through the bottom of it. Turns out it was less than paper thin. Thankfully he didn't have any troubles finding a replacement.
I spent last saturday at an antique tractor show. There are a lot of passionate ol' folks collecting these things. Usually if they have 1, they'll have 5 or 6 other models of the same brand. Even got to see a Porsche tractor, which was pretty interesting.
joeslob is offline
Old 09-20-2008, 07:10 AM   #7
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
I was going to use 20/40 slag because some of the parts are pretty pitted. I thought any finer would heat up faster. What is your opinion?
Old 09-21-2008, 09:31 PM   #8
Todd
blastserv's Avatar
Trade: media blasting
i almost soley use starblast and am unaware of all the different numbers in front of the medias and how they change the grit but i am sure if the media you are using is the finest you can get in that type it will be o.k....but,do not however find yourself sitting in one spot for long at all and defiantley keep a 45 degree angle.you should also turn down the pressure to 45 and start there and work slowly up.
www.blastserv.com
blastserv is offline
Old 10-02-2008, 11:45 PM   #9
user20594's Avatar
I used to work tractors as my main company. Travis Jorde is the only and best contact for the repair and fix of almost all old tractors. He has an ad in the green magazine. I used to be his painter
user20594 is offline
Old 10-02-2008, 11:49 PM   #10
user20594's Avatar
I would think that Trav would have an on-line page if he does not try green magazine dot com or look up the history of john deere.
Old 10-03-2008, 12:34 AM   #11
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
I got the gas tank, hood and the thicker side pannels done. I have the sub frame and the thin stuff left to do. Ill try and get some pics this weekend, I have to work all weekend so wont have time to finish it up.
Old 10-04-2008, 10:09 PM   #12
user20594's Avatar
on most all tractors 20/40 is way to harsh on all of the machine. You will wreck seals, gaskets, and filters. The first thing you have to do on an old restoration is wash it first. 1500 psi steam wash if you do not have a power washer then scrape or hand tool all of the old built up oil off of the tractor. the main parts on a farmall will be the wheel seals the oil pan and the bottom of the gas tank. Provided it is a gas model. If it old enough the head gasket and spark plugs will need special care to. The carb. on these tractors drip gas no mater what you do. Another big leak on these models is the PTO. If the t4ractor you are going to blast has been switched to twelve volt watch out for the altenater . Use alot of duct tape on it or you will have to replace it.. On the sheet metal if you are good enough you can remove dents. Use your nozzle to heat up the metal untill it starts to move put it back where it should be. Dents that are pushed in can be warped out. Dents that are pushed out can be warped in. it takes time and it will not be perfect but that is why I learned how to do body work. Every truck I have on the road I built. I learned that from building tractors
Old 11-10-2008, 01:14 AM   #13
Chris
killzoneq2's Avatar
Trade: SANDBLASTING
Here is a pic of some of the stuff I did.
Old 01-15-2009, 08:54 PM   #14
hdm2002's Avatar
Trade: landscaping
Hello I am new to this site but I thought I would share some pics of My John Deere that I sandblasted and restored. I used silicia sand and I blasted everything everyone talks about warping but you just need to keep the media moving dont stay in one place to long.
Blasting sheet metal off old farmall-102_0562.jpg   Blasting sheet metal off old farmall-102_0640.jpg
hdm2002 is offline
Old 01-16-2009, 12:29 AM   #15
user20594's Avatar
Travvis Jorde ,
he can send you the decals for your tractor
I dont know what you have but he will
Old 01-16-2009, 06:43 AM   #16
hdm2002's Avatar
Trade: landscaping
Since the photo was taken I have put the decals on the tractor, but thanks for the advice. I will try and take one more with every thing complete.
hdm2002 is offline
Old 01-16-2009, 08:28 AM   #17
woodchuck2
woodchuck2's Avatar
Nice job on the tractor. I missed out on a 45 Farmall cub that was in very good condition and used every summer for cutting fields. The guy sold it for $2k. I do know of a John Deere model B high crop sitting in the woods. I asked the owner about selling it but he says no for now. He bought it for $50 about 20yrs ago and it has sat in his back yard ever since.
woodchuck2 is offline
Metal roofing Help The Boys Roofing 9 08-22-2008 09:28 PM
Metal Framing Help gambinos1983 Framing 7 04-06-2008 08:01 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
