Blasting Moulds
Old 11-09-2009, 10:20 AM   #1
Oz man's Avatar
Trade: maintenance
Blasting Moulds
Hi Lads, I tried to dry ice blast a rotational mould for a customer, the mould is coated with a uPVC type release agent, when applied previously it is then baked on. the DIB would not remove it, so my next option is a grit but for obvious reasons i cant damage the underlying surface. the pvc coating didn't really work for their process so it needs to be removed, any idea's on a type of media???
Oz man is offline
Old 11-09-2009, 02:53 PM   #2
Master Blaster!
BLASTPRO's Avatar
Trade: Sandblasting and Coatings
Re: Blasting Moulds
hit it with walnut, we have had luck with it in the past were nothing else would work, soda might work but I don't think it would be aggresive enough. Good luck.
BLASTPRO is offline
Old 11-09-2009, 06:00 PM   #3
Glen
Betterblast's Avatar
Trade: Media blasting
Send a message via Yahoo to Betterblast
Re: Blasting Moulds
Oz, you didn't say what the mould is made of. I agree walnut is a good choice t try before an abrasive. I would maybe hit the back of the mould first to see if you get damage.
When it has to be clean, Betterblast it!
glenmarcinc@yahoo.com
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 11-10-2009, 04:04 AM   #4
Oz man's Avatar
Trade: maintenance
Re: Blasting Moulds
Thanks for your replies, the mould is made of metal, don't know what grade etc
Oz man is offline
Old 11-10-2009, 06:36 AM   #5
Glen
Re: Blasting Moulds
Walnut or soda won't damage any kind of metal that I am aware of. even at higher preassure. The Soda might be the better choice if there are small pockets in the mould that would be hard to clean dust and particles from. The soda is water soluble. But I think the walnut would strip better if it is not too intricate a mould.
P-610-323-8084
If you were not doing blasting what would you be doing Idontknow Sandblasting 15 10-05-2009 08:58 PM
dry ice blasting? zeke1 Sandblasting 8 10-02-2009 07:59 PM
sand blasting boo boo`s? ausisoda Sandblasting 6 09-03-2009 01:34 PM
soda blasting and compressor size ausisoda Sandblasting 14 06-02-2009 07:16 AM
Powder Coating and Media Blasting, Illinois YSRRider Specialty Coatings 2 05-26-2009 07:03 PM
