Blasting Log Home
Old 04-01-2011, 06:10 AM   #1
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
Blasting Log Home
I know pricing isn't something we talk about here, but a gentleman with a log home had me come out to do a test blast on his home.
The test blast produced excellent results with both products.
I gave him 2 prices per square foot, one was with recycled glass and the other was with walnut shells.
I've done two smaller log homes, but this one is much larger and I was wondering what others charge around the country to do the same type of home and again I'm looking for square foot prices?
Thanks
Dale
MasterBlaster is offline
The Following User Says Thank You to MasterBlaster For This Useful Post:
LogHome (02-06-2013)
Old 04-01-2011, 10:08 AM   #2
Bob
Sand Pot's Avatar
Trade: Abrasive blasting
Rewards Points: 882
Re: Blasting Log Home
Dale, how are you getting walnut shell to flow in your wet Farrow pot?
Sand Pot is offline
Old 04-01-2011, 02:07 PM   #3
fitter's Avatar
Trade: hvac
Rewards Points: 33
Can you post before and after pic's?
fitter is offline
Old 04-01-2011, 05:11 PM   #4
Rewards Points: 838
Hi Bob, The walnut shell media I'm testing with didn't cut like I had wished. On dirty wood it made it look freshly milled, but on coated wood it was like beating your Di@# on it... if you what I mean.
I still have some experimenting to do with the walnut shells... when they're flowing they work great, but I'm having problems with the walnut shells clumping up and clogging the bottom of the pot... when that happens they just let water through... and yes walnuts do sink when you place them in water.
The problem with this log home is someone painted the logs with wood colored paint and the new owner wants it all removed.
The New Age fine recycled glass worked great on the painted wood and didn't hog out the wood like medium recycled glass might have.
Old 04-01-2011, 05:20 PM   #5
Rewards Points: 838
It was snowing and raining today when I did the test blast and I wasn't in the mood to take pictures after words. (I was cold and wet)
The client was very pleased with the area we test blasted and wants it done this month, only problem is I'm swamped with work and can't touch it until the end of May.
I have to work up a price and don't want to undercut anyone, I'm trying to get an idea what's everyone charging to blast log homes by the square foot?
This house has an exterior area of about 5000 square feet.
Thanks
Old 04-02-2011, 01:17 AM   #6
ausisoda's Avatar
Trade: abrassive blasting
Walnut shell would be useless in a wet blaster it is a soft media wetting it would make it unable to cut.
Dry blasting walnut works very well.
ABSS supplies.
For a bullet proof blasting machine made in Australia they should be your first choice.
They produce top quality equipment that will give you hours of trouble free blasting.
Their customer service is the best in the business.
ausisoda is offline
Old 04-02-2011, 07:17 AM   #7
Rewards Points: 838
Actually the walnut sells cut fine wet as long as they're flowing.
The problem is at the bottom of the pot they act somewhat like a sponge and will bind up at the exit hole only allowing water through..... and no media.
I've had walnuts in water up to 24 hours that still performed well.
The clogging is the issue.
Old 04-03-2011, 09:23 PM   #8
Master Blaster!
BLASTPRO's Avatar
Trade: Sandblasting and Coatings
Rewards Points: 150
use the glass, ive done numerous homes with it and it works far better in the scope of the job than walnut. We never charge by the square. We take into efffect all windows gutters, neighboring homes, lawn work, accesibility etc etc etc and just come up with a bid off of that. Prep is everything, make sure windows are covers well and gutters too. We did a home a few years ago that was about 15k. It was a larger home that took 3 of my guys 4 or 5 days to complete and that was alot of prep and blasting.
BLASTPRO is offline
The Following User Says Thank You to BLASTPRO For This Useful Post:
MasterBlaster (04-04-2011)
Old 04-04-2011, 05:21 AM   #9
Rewards Points: 838
Thanks BLASTPRO, I thinking 4 to 5 days as well.
This log home is a rancher thats on a hill... so the back and sides of the homes are going to need to be scaffolded.
The front of the house is ground level but the back has a walk out basement and is up one level (second floor)
Total surface area of around 5000 square feet.
The logs are painted and the seams are sealed with calk.
If looks like it's going to be a fun job.
Old 02-06-2013, 10:36 PM   #10
LogHome's Avatar
Rewards Points: 135
Colorado Log Home Media Blasting, chinking, staining and restoration of cabins and wood sided homes.
Log Home Finishing LLC - Serving Summit County and Park County and other Colorado mountain locations. Certified log home expert.
LogHome is offline
Old 11-17-2014, 08:09 AM   #11
tutone's Avatar
Trade: Log Home Finishing
Rewards Points: 160
Who does media blasting in winter?
tutone is offline
Old 11-17-2014, 08:58 PM   #12
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 862
I blast all winter
in Maine
last year we was doing a mill
job inside no heat
-18 degrees one day.....
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 11-30-2014, 12:11 PM   #13
M&RMMB's Avatar
Rewards Points: 60
I've done a log home with the 30/60 crushed glass seem to work better dry the when I tried wet. I go with a hourly actual blasting rate of $150, but leave it to them for all prep and clean up.
M&RMMB is offline
Old 12-17-2014, 02:03 PM   #14
Bob Moore's Avatar
Trade: Media Blasting
Rewards Points: 130
Red face
We blasted a small log home in Oct. We have a GB-400 and used 120 grit garnet. Set pressure at 60 PSI and had 150 feet of hose with a #7 nozzle. Worked extremely well and customer very happy. We also had customer cover all windows. No clean up. We were blasting a clear varnish off. Garnet is a med. red media and with the pine cones and needles, just hoses the ground down, the media just drops below the surface and you never see it.
Bob Moore is offline
Old 12-23-2014, 08:56 PM   #15
Bob Moore's Avatar
Rewards Points: 130
MasterBlaster, you said that walnuts work ok. I thought I read somewhere that you also had a geo blaster. Have you tried walnuts in the GEO?. I want to try them on cars where the glass has NOT been removed.
Old 12-24-2014, 07:37 AM   #16
Rewards Points: 838
NO! Walnuts in wet abrasive systems turn to mush.
Any walnut blasting I do I do it with a dry system.
On log homes I use either glass, walnut or corncob depending on what I'm looking for with the end result.
Some log homes I blast wet, others I blast dry.
Old 12-25-2014, 12:57 AM   #17
rydndirty's Avatar
Trade: Future blaster
Rewards Points: 70
Dale, what's your determining factor on which log homes you blast wet/dry? vegetation, surrounding's. customer preference.
does the dry blasting give it more of a sanded finish, thanks
rydndirty is offline
Old 12-25-2014, 09:54 AM   #18
Rewards Points: 838
Mainly if it's finished with paint. Here in New Jersey you have a lot of old log homes which are painted for some stupid reason.
If the log home is just dirty or has an older oil stain I blast it dry most likely with glass.
Interiors I only do dry and most often with walnuts of corncob.
Old 12-25-2014, 01:13 PM   #19
Bob Moore's Avatar
Rewards Points: 130
Dale, you just mentioned that you use glass, would that be med. or fine. Have you used Garnet on log homes.??
Old 12-25-2014, 05:05 PM   #20
Rewards Points: 838
40-70 medium recycled glass on log homes dry... sometimes wet if there is old paint on the logs.
I use Garnet only on stubborn coatings on metal... did a bunch of military tanks for a museum and we did it wet using Garnet and Holdblast.
PA. Home Improvement Act 132 !!!! Nail Ace Contractor Licensing 9 08-05-2011 11:03 AM
home maintenance bigonsmalljobs Marketing & Sales 1 01-21-2011 10:37 AM
bidding exterior paint home hopper1913 General Discussion 3 11-17-2010 07:22 PM
Uh-oh, the Big Drop is stalling out. Mike Finley Marketing & Sales 7 12-12-2008 05:05 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
