Kelly
Trade: Media blasting
Blasting Inside A Car
I looked at a mustang today and a guy has rust on the inside of the roof of his car that he is stripping down to be restored. It's a late 60's mustang has rust with insulation stuck to it. He figures it was in a high moisture environment and water must have condensed up under the head liner. Soda won't take the rust out so I could use glass but it's thin metal after the rust comes off don't want to warp it on the other side of the upper quarter panel and roof. What about walnut?
Tony
Trade: Media Blasting and Powder Coating
Re: Blasting Inside A Car
We use medium glass all the time it will work fine. I have no warping problems with using glass.
Tony
www.bulldogblasting.com |
Master Blaster!
Trade: Sandblasting and Coatings
No problem with using glass what so ever, we just did a 35k resto project Chevelle. The roof of the car had the same adhesive you are talking about. It came off clean and no heating issues. Good luck.
Glen
I agree with the glass. And by the way, walnut won't take off rust either. It does the same thing soda does.
When it has to be clean, Betterblast it! glenmarcinc@yahoo.com P-610-323-8084 http://betterblast.com/ |
Kelly
Thanks for the info on the walnut I figured it wasn't going to take rust off I will have to use the glass.
Trade: SandBlasting/Soda Blasting
Shoot the glass from a angle not dead on, move to different spot from time to time, (just in case )
The older cars have a heavier metal, done lots with glass no problem. But would tell the guy up front that is it the only way to get the rust off and there May be a slight chance of warping due to the change in the metals surface tension JUST TO COVER YOU’RE BUTT!
It's one persons stuppid question; that many want to know the answer to. Web Site: www.DyerSodaBlast.com Email: Jim@DyerSodaBlast.com |
| dry ice blasting? | zeke1 | Sandblasting | 8 | 10-02-2009 07:59 PM |
| all 30 amp fuses from the inside | handyman99 | Electrical | 11 | 09-05-2009 09:49 PM |
| T&G pine - inside, oustide corners? | sorethumbs | Carpentry | 5 | 05-06-2009 12:23 AM |
| Questions Shower Handle Inside | matthewcims | Plumbing | 3 | 02-23-2009 11:01 AM |
| Black marks left by inside corner applicator | AARC Drywall | Drywall | 5 | 10-04-2008 09:41 AM |
