panderson2414
Kell at first I thought you had a moisture problem but your in Arizona so it should not be that. Then I thought you may be choking your pot, but if it will run for a short time the idea I had is your auto air valve may have a pin hole in it. The pin hole will make your pot choke itself that will lead to the chugging your getting at the nozzle. The only other idea I have is the valve you are running will not meter out a fine grade abrasive like glass. I have only run glass in my SX 13 this pot was made for soda only. Glass had not been invented when the pot came out. The valve on this pot is not even close to a blast pot. My question for you is what are the variables, vlave type, dead man controls, moisture, compressor type. When a compressor gets some age on it the air and oil seperator element needs to be changed oil in your lines changes the whole deal
