Blasting A Bronze Statue
Old 11-07-2013, 11:56 PM   #1
kauai88's Avatar
Trade: surface prep contractor
Rewards Points: 111
i have been asked to blast a 300,000 dollar bronze statue does anybody have any experience in blasting bronze statues ?
my current setup is a sullair 375h after cooled compressor and a 600lb pot and plan on using 180 grit Aluminum Oxide with a number 4 nozzle any suggestions? I was considering wall nut shells but the guy finishing it does not want a polished surface thank you in advance.
kauai88 is offline
Old 11-08-2013, 10:25 PM   #2
kauai88's Avatar
Rewards Points: 111
Re: Blasting A Bronze Statue
nobody has any input? or experience in this?
kauai88 is offline
Old 11-09-2013, 09:26 AM   #3
K&B Plus...
Live_oak's Avatar
Trade: Kitchen Designer
Rewards Points: 154
Removing the patina from bronze devalues the item big time for most art collectors that I know. They would be horrified by the project. That's probably why you're getting the big silence here. It's just not really done very often unless graffiti contamination is involved, and that usually involves chemical removal, not abrasives.
Not that I'm experienced on anything blasting other than second hand watching my husband do it, but I would think the setup that you describe is much too abrasive for bronze. It's mostly copper after all. Something infinitely more gentle would seem to be called for if the details on the statue aren't to be lost. Here's where I show my ignorance for sure.... what about soda blasting?
Live_oak is offline
Old 11-09-2013, 04:11 PM   #4
kauai88's Avatar
Rewards Points: 111
we are blasting it because it is used a water feature so it has build up of calcium / lime deposits .
baking soda would turn the bronze green so i am told
kauai88 is offline
Old 11-09-2013, 05:26 PM   #5
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 862
Question is: "considering wall nut shells but the guy finishing it does not want a polished surface..."
why?
low psi air and a really fine glass ? would leave a low profile
turn up psi till you get were you need it?
But having a profile would let things stick to it worse over time???
What about glass beads?
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlast.com
Email: Jim@DyerSodaBlast.com
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 11-10-2013, 07:35 AM   #6
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
Blast it dry with fine walnut shells.... this way you keep the patina and you'll remove the crap calcium and lime deposits.
MasterBlaster is offline
Old 11-10-2013, 09:20 AM   #7
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
Send a message via Yahoo to Betterblast
Go with the shells but just his foot or a finger and let the owner decide.
When it has to be clean, Betterblast it!
glenmarcinc@yahoo.com
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 11-10-2013, 02:58 PM   #8
kauai88's Avatar
Rewards Points: 111
why?
yea for sure we are going to do some test spots.
but the object is to remove the patina because they are going to re-patina the statue.
anyone have experience with aluminum oxide? the blast shop on oahu was telling me that since the grit is so fine with the A.O it tends to clump and recommend and air dryer of some sort but I do have an After cooled and filtered compressor
how do you post pics? I have a pic of it
kauai88 is offline
Old 11-10-2013, 07:02 PM   #9
Rewards Points: 838
What's the texture of the bronze statue... smooth or sand casted?
If it's a smooth finish you might want to go with fine glass beads at 35 and 45 psi
If it's a sand cast finish then real fine recycled glass at between 35 and 45 psi
Old 11-10-2013, 07:19 PM   #10
daniels_gt's Avatar
Trade: blasting company
Rewards Points: 12
If you have lime and calcium deposits. You should try spraying vinager or even coca cola, that removes this type of deposits within a couple of minutes and then you just need to wash it off. The walnut shell at low psi sounds as a promising solution. Regards,
daniels_gt is offline
Old 11-17-2013, 04:12 AM   #11
DIOXID.RO's Avatar
Trade: GKO Cryosonics SRL
Rewards Points: 42
Send a message via Yahoo to DIOXID.RO
Dry ice blasting with fragmentation nozzle is the best solution, powerful cleaning yet gentle and non-abrasive for the surface...
DIOXID.RO is offline
Need Blasting Equipment AND advice.... fishwich2005 Sandblasting 4 09-02-2014 09:54 PM
Bridge Blasting ccogan05 Sandblasting 24 04-07-2014 10:13 AM
Dustless Blasting. Info please Dyer Sandblasting 19 10-16-2013 07:18 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech General Discussion 0 08-16-2010 11:07 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech Tools & Equipment 0 08-16-2010 10:57 AM
