Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Sandblasting
Old 08-18-2009, 11:54 PM   #1
Trade: Sodablasting/ Sandblasting
air hose/blast hose
What size hoses are you guys using? I currently have a 375cfm compressor with 1 1/2" I.D. Air hose and 1 1/4" I.D. Blast hose with a #7 double venturi nozzle.
blastoffinc is offline   Reply With Quote
Old 08-19-2009, 12:39 AM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
That is pretty much the Norm for that set-up. If you are using say 150' or more of blast hose then you might would want to bump the air line to 2" just for volume purposes is all. I have my contractors to run 1 1/4" blast hose all the way to the nozzle. The last 50' of hose is the Clemco Supa-Flex hose. It is the same outside diameter as a 1" blast hose, but the ID is of a 1 1/4" blast hose. You loose less pressure this way. All hoses should be sized correctly to reduce pressure loss as much as possible. I hate seeing people using a 185 compressor and running a 3/4" airline to their blast pot and then running 1 1/4" Blast hose to the nozzle and then having to run a #4 or #5 nozzle to keep the pressure up.
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is offline   Reply With Quote
Old 08-26-2009, 10:51 PM   #3
Know your Role
Trade: Industrial blasting & specialty coating contractor
I have the same compressor and run 225 ft regularly. I use 1 1/2" for the 100 ft. 1 1/4" the 2nd 100 ft. and then the Marco 1 1/4 ID whip hose the last 25 ft. and it works great.
http://www.thepaintpro.com
I strongly feel that most people refer to themselves as professionals at their trade long before that title actually fits.
Blastman is offline   Reply With Quote
Old 08-27-2009, 12:01 AM   #4
Todd
Trade: media blasting
185cfm
have gone as long as 175 ft air line of 1 inch air line
50 ft 3/4 id marco blast hose
#5 nozzle
any one see where i could be more productive let me know...thanks
www.blastserv.com
blastserv is offline   Reply With Quote
Tip for cleaning a used AIRLESS HOSE MZ-HANDYMAN Painting & Finish Work 17 10-03-2009 04:17 PM
Blasting hose questions? edjohnson Sandblasting 17 12-27-2008 07:40 PM
broken hose on JCB 214-can I isolate hyd's 72chevy4x4 Excavation & Site Work 2 09-01-2008 09:05 AM
New Roof Cleaning Hose - Thanks Dave! Roof Cleaning Pressure Washing 0 07-22-2008 08:09 PM
Hose Reels killzoneq2 Sandblasting 4 05-07-2008 07:52 AM
