Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Sandblasting
Old 08-21-2009, 11:51 PM   #1
Trade: MV restoration
Air compressor combinations
I saw in another thread someone asked if you could hook two 150cfm compressors together to get 300cfm. It wasn't answered so that is why I am starting a new thread. I hope to combine a 150cfm and a 190cfm compressor to get higher cfm rating. That will allow a larger blast tip for quicker base removal, correct?
gimpyrobb is offline   Reply With Quote
Old 08-22-2009, 08:51 AM   #2
Todd
Trade: media blasting
sounds like to me the cost of running two compressors is gonna make it cost in-effective...but air is air and if you find a way to make them both go into one device without the air from one trying to fight its way into the outlet of the other one then it should work but i have serious doubts you will be able to get that part figured out.
www.blastserv.com
blastserv is online now   Reply With Quote
Old 08-22-2009, 12:11 PM   #3
Trade: Sandblasting
I haven't personally seen, but have heard that (especially in fields with HUGE air compressors like the mines) some guys can synch big, 1000+ CFM compressors together so they don't blow the oil out the other one's screw when they aren't pumping at the same pressure. I've also heard that some guys just get lazy and slave one's controls to the other so they rev at close to the same pressure at the same time...
Greenbuggy is offline   Reply With Quote
Old 08-22-2009, 10:34 PM   #4
Souds like it might be better to just find another pot and have two guys blasting. Thanks for the info, I never thought about one overpowering the other. I guess 2 check valves the size needed for this much cfm would cost an azz load too.
BACK TO THE DRAWING BOARD!
Old 09-12-2009, 04:37 PM   #5
Trade: Bicycle Powdercoater
As new user I feel horrible for this necromancy but I think I have some good .02
The phenomenon of "one compressor overpowering the other" only happens if A) one compressor is running at a higher PSI or B) the compressors are charging out of sync.
A check valve can remedy this.
Mating two compressors is not that hard to do, Will cost some because fittings will have to be bought to make the custom plumbing. It works best with TWIN compressors. Set the regulators on both to identical PSI and charge them up simultaneously and there should be no extra work for either.
yakmastermax is offline   Reply With Quote
Old 09-13-2009, 11:05 PM   #6
PRO
panderson2414's Avatar
Trade: industrial coatings, sandlbasting,sodablasting, an
panderson2414
grimpy, I have restored tractors and cars for years. I have often run into guys that can afford to have their equipment restored at a good rate. Are you an asshole? pa
panderson2414 is offline   Reply With Quote
Old 09-13-2009, 11:07 PM   #7
PRO
panderson2414
I like to work but I Hate cheap ****ers
Old 09-13-2009, 11:20 PM   #8
PRO
panderson2414
if you bought a used helmet and a a used pot and have used eveything , How the **** do you help out me.... how does your used up **** help my three kids. I have tried to help people out but wtf Send me money Ill help you. f off
Old 09-13-2009, 11:26 PM   #9
PRO
panderson2414
This is for real. I have a two year old and two other kids, nine and four, I provide these kids shelter and homes with sandblasting. It is our lives. Dont take it easy. It is my life, PA
Old 09-14-2009, 11:08 PM   #10
Panderson, I'm sorry your kids have an ass for a dad. I hope you are gone alot so they don't grow up like you. I do the best with what I got. Aren't you the one that post how awesome you are? Go post in others threads if you have nothing contructive to add.
Old 09-15-2009, 10:28 PM   #11
Trade: Dry Ice Blasting
what happened here? I'm lost? did I miss something behind the scenes?
I guess you got to work with what you have...good luck.
CO2Solutions is offline   Reply With Quote
Old 09-15-2009, 11:08 PM   #12
Dunno, I hope he was drunk or something. No reason for it really.
