Spraying Elastomeric Roof Coating
Old 10-20-2008, 11:58 AM   #1
CNC's Avatar
Trade: Electrician
what sprayer would i use to spray an elastomeric roof coating? can any airless sprayer do it, or do i have to get a special one?
CNC is offline
Old 10-21-2008, 10:33 AM   #2
John the estmtr's Avatar
Trade: Painting: Commercial, High Rise, Custom, Residential
Re: Spraying Elastomeric Roof Coating
Airless works just fine. Get yourself a big ol' tip in your gun and you're good to go.
Experience: Formerly an outside sales rep for a paint manufacturer. Was offered a better job as an estimator for a paint contractor company and never looked back. So when I give my .02 cents, well it still doesn't matter...
John the estmtr is offline
Old 11-24-2008, 08:37 PM   #3
DCAM's Avatar
Trade: 2 Component Coatings
Fast set elastomerics work great and provide a pure monolithic membrane. We used a 2 component machine from a company in Ohio that was very cost effective and put it down fast. The real neat part is you can walk on this stuff in minutes compared to other types and weather isnt a real issue, providing the surface is dry, due to it curing exothermicly; chemical reaction. The coating has aluminum powder in it and reflects UV rays to the point of 30-40 dgrees cooler than any other roof product weve seen.
Some people don't care for the two component machines but we had no issues. This one project paid for the rig and still had steak for dinner
DCAM is offline
Old 11-29-2008, 05:59 PM   #4
Dmax Consulting
Dmax Consulting's Avatar
Trade: Paint Contractor
Depending on the type of coating, you should be able to use any sprayer that is strong enough to atomize the coating. If you are leaving the sprayer on the ground, keep in mind that you will need a strong sprayer to push the material up and through the hose. Graco 5900, 7900, and gas-hydralic rigs all should work.
Dmax Consulting is offline
Old 12-10-2008, 11:25 PM   #5
President of the world
world llc's Avatar
Trade: general contractor
try a graco mark IV or a mark V... these machines can pump peanut butter!!
world llc is offline
Old 12-11-2008, 07:14 AM   #6
NAV's Avatar
Trade: commercial building restoration
Graco
BulldogŪ 33:1 & 41:1
Air-Powered Airless Sprayers
this pump will move some material fast. you can run 6 lines off it easy for Uniflex, Dryfall, whatever material you need 6 guys spraying with.
We own 3 similar units and have had no problems with them. If you want more info google the Bulldog 33:1 paint sprayer.
NAV is offline
Old 01-18-2009, 12:43 PM   #7
Project Manager
WePaintIt4u's Avatar
Trade: Industrial Painter
Originally Posted by Dmax Consulting View Post
Depending on the type of coating, you should be able to use any sprayer that is strong enough to atomize the coating. If you are leaving the sprayer on the ground, keep in mind that you will need a strong sprayer to push the material up and through the hose. Graco 5900, 7900, and gas-hydraulic rigs all should work.
Excellent advice and remember to remove filters from gun(s) and pump.
WePaintIt4u is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Coating for metal trailer roof? buildenterprise Roofing 1 08-30-2008 09:24 PM
Spray Foam Roof Coating - Advice firemike Roofing 13 04-14-2008 07:08 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
