Trade: Painting and Decorating
Shield Crete Coverage
Hi, This is my take on the shieldcrete
http://www.hcconcrete.com/products/s...ting/index.jsp very good covering power but the coverage rate as per instructions were a mile out (they say between 200/250 sqft depending on the porosity of the substrate)all we got was about 140 sqft per gal and you don't even get a full gal. Although our garage floor had been grinded and therefore more porous. I still think there estimate is way off, btw I used 1/2 purdy colosous sleeve which I found to be just right, any shorter and you would be struggling to fill the low spots any longer and you would have trouble spreading the toffee like material.When it's drying it tends to look a bit discoloured as if you have been a bit shy with the paint but it as it dries out it becomes more uniform Appears to be a good product but make sure when estimating you allow for more paint than it says in the enclosed instruction Hope this helps anyone thinking of using it. Regards David |
Trade: Painting Contractor
Re: Shield Crete Coverage
I have used it. i found it to be about 200 sqft coverage. I used the recommended 3/8 nap. I had a 750sqft floor to do. 4 og their kits and 2 gallons of their sealer.
Sean |
hhmm, our floor was 730sqft and it took Just over 5 gl, diff must be down to the porosity of the floor.
| H&C Shield Crete Epoxy | 420sully | Painting & Finish Work | 20 | 05-27-2011 03:28 AM |
| Help, old shingles stuck to ice shield??? | 232323 | Roofing | 45 | 09-16-2009 04:27 PM |
| shield material | Cache | Painting & Finish Work | 28 | 02-10-2009 11:00 AM |
| MI Ice & Water Shield Reg Interpretation | lituani | Roofing | 3 | 10-26-2008 09:58 AM |
| hilarious WP article on the hurricane news coverage | 31b | Off Topic (Non Trade) | 2 | 09-07-2008 03:33 AM |
