Trade: Painting Contractor
Sanding Sealer Help
Can polyurethane be applied over a sanding sealer? Or what can't be applied over a sanding sealer may be a better question.
#2 | |
My custom title
Re: Sanding Sealer Help
yes
almost nothing
Benn Quote:
#3 | |
Paint Pro/Faux Artisan
Trade: Painting Contractor/Faux Finisher
Re: Sanding Sealer HelpQuote:
Bay Area Painting Company and Faux Finishing |
Trade: Paperhanger/painting contractor
Most sanding sealers contain stearates and most of the polyurethanes I have seen recommend NOT applying over anything with stearates due to adhesion problems. Look for a sanding sealer specifically for use under poly and you'll be fine.
painterofeverything
or try dewaxed shellac.....such as bullseye first coat
Sorry- I should have clarified. Definitely use the dewaxed shellac, I love first coat- use it on all my faux and enhanced grain finishes.
The problem is in the adhesion- it looks good but if you attempt to put tape on it, it can pull off to the sealer- which is why it's important to use something like the Seal Coat... Bay Area Faux Finisher |
| Sanding Sealer | plumbco | Painting & Finish Work | 12 | 09-01-2008 03:25 AM |
| concrete sealer | kermmonk | Construction | 3 | 08-01-2007 07:26 AM |
| pine sealer ...... | Vermonster | Painting & Finish Work | 9 | 07-21-2007 10:16 PM |
| Drywall Sanding Sponges? | Abrasive Dan | Drywall | 6 | 06-14-2007 05:35 PM |
| sanding problems- will primer then sand fix? | D-ball | Drywall | 1 | 12-26-2006 01:36 PM |
