Trade: Garage Remodeler
Respirator Survey
Hey All , Would Like Some Input On What Sort Of Breathing Aparatus / Respirator I Should Be Looking At Purchasing ...i Will Be Putting Down Epoxy With A Polyurea Top Coat ...saw One By Msr At The Big Orange Place But It Did Not Qualify For Urethanes ...any Help Would Be Appreciated ..thanks Rm Feel Free To Leave Some Links .
Re: Respirator Survey
Look here. http://www.fgci.com/
Maybe one of these
Professional Remodeler
Gotta work fast though, you only get about 20 - 25 minutes of air with an SCBA
-Mike- Falcon Contracting Residential - Commercial
painterofeverything
check out a fresh air respirator,a bit pricey but oh so nice !!
painter is right, most manufacturers of urethanes recommend the use of SABA's (Supplied Air Breathing Apparatus) when using urethanes, many contain some rather volitile chemicals, some which displace oxygen, which is the reason for positive pressure respirators. There are many types of urethanes, some are less dangerous than others.
A company I worked with wouldn't even let you take your protective suits out of the work staging area because of the possability of contamination to other areas. You should consult with the manufacturer of the product you are using for all the specific details. We used some urethanes that were relatively safe, all they required was fresh air ventilation or positive pressure ventilation and standard organic vapor cartridges. The manufacturer can tell you everything you need to know.
