Removing Paint Droplets From Hardwood Floors?
Old 07-23-2017, 09:01 PM   #1
BrooklynBravest's Avatar
Trade: Carpentry - Welding/Fabrication
Rewards Points: 790
I don't usually paint but decided to after some molding work and wasn't paying attention, got a lot of little spatter droplets of paint on freshly refinished oak floors.
Floors I believe have oil base poly over them. Paint is latex.
I tried goo gone latex paint remover and that was worthless. I know something like goof off will get the job done but I worry it will damage the floor finish.
BrooklynBravest is offline
Old 07-23-2017, 09:04 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,375
Re: Removing Paint Droplets From Hardwood Floors?
Fingernail or old credit card (something plastic). I like to use my AAA card.
I suppose a plastic putty knife would look more professional.
MarkJames is online now
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
TNTSERVICES (11-20-2017), VinylHanger (07-23-2017), Wile E Coyote (07-25-2017)
Old 07-23-2017, 09:13 PM   #3
Rewards Points: 790
I tried the plastic putty knife, a brand new one and it just skated over the paint. Fingernail works but I feel like their has to be a better way than 8 hours on my wearing my nail down to skin.
Old 07-23-2017, 09:15 PM   #4
MarkJames's Avatar
A better way? Dropcloths and technique! (and better paint, maybe)
Use a credit card (or anything else) at a steeper angle. Use corners of the tool, as necessary. Do it before they notice, so as to not draw attention to it all.
pinwheel (07-23-2017)
Old 07-23-2017, 09:27 PM   #5
Rewards Points: 790
It's Benjamin Moore it should be good paint lol.
Ugh
Old 07-23-2017, 09:32 PM   #6
MarkJames's Avatar
Ugh
They have watery stuff, too (that isn't cheap).
Don't forget to use very good brushes. Absolutely worth it. The payback is almost immediate.
Old 07-23-2017, 09:32 PM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,194
If you were one of the regular builders I work for & you called me & asked what to do, I'd come sand it off & touch up the problem areas.
Don't use anything hot, like lacquer thinner or acetone. Petroleum or citrus based cleaners shouldn't hurt oil based poly.
pinwheel is offline
The Following 3 Users Say Thank You to pinwheel For This Useful Post:
jstanton (11-20-2017), MarkJames (07-23-2017), TNTSERVICES (11-20-2017)
Old 07-23-2017, 09:34 PM   #8
MarkJames's Avatar
Thank you x3 for that.
Old 07-23-2017, 10:00 PM   #9
hdavis's Avatar
Rewards Points: 8,021
Single edge razor blade and a little mineral spirits for lube, dull the corners, and bow the blade a little. Ethanol will dissolve it eventually.
You can usually get those off with a red pad. Latex will also redeposit and stick like crazy, so don't let it sit once it's loose, get it up.
hdavis is offline
Old 07-23-2017, 10:03 PM   #10
hdavis's Avatar
Spatter is usually a rolling issue - rolling too fast for the paint/cover combination. Some paints are REALLY bad about it. IMO, only use paints you can roll fast and not have spatter issues OR cover the floor....
hdavis is offline
Old 07-23-2017, 10:18 PM   #11
tjbnwi's Avatar
Rewards Points: 2,898
Denatured alcohol dissolves latex paint, wont affect oil based finish.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
parkers5150 (12-24-2017), SuperiorHIP (07-23-2017), TNTSERVICES (11-20-2017)
Old 07-23-2017, 11:24 PM   #12
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,344
For latex paint over an oil based paint denatured alcohol will cut the latex and will not affect the oil based. If it is new latex paint drops (within a few days) over oil a wet rag and some elbow grease will take care of it.
SuperiorHIP is offline
Old 07-24-2017, 10:41 PM   #13
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,122
Krud kutter graffiti remover is EXCELLENT for this problem. Works well on windows that get over spray as well.
Sent from my SM-N910T using Tapatalk
sparehair is offline
Old 07-25-2017, 10:14 AM   #14
Texas Wax's Avatar
Rewards Points: 824
Latex splatter on oil base floor finish ... try alcohol. It generally softens latex paint and should do no damage to the floor.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Old 08-27-2017, 01:01 AM   #15
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 7,312
I don't usually paint... .
I miss the old solvent based Goof-Off that is no longer available due to environmental restrictions. Maybe it was the Xylene or something. Now it's pretty much thinned down lacquer thinner. The water-based Goof-Off is just water and alcohol.
Caslon is offline
Old 08-27-2017, 01:02 AM   #16
Caslon's Avatar
What?, professional courtesy and all? Feel free to to use the DIY forums too.
Caslon is offline
Old 09-26-2017, 07:46 PM   #17
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
Mineral spirits should work.
DiaperRiot is offline
Old 11-20-2017, 08:50 AM   #18
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,214
That is what I would use. On the rag, not the floor, just long enough to remove.
What you don't use you can later rinse out your brushes in...
-Art
artinall is offline
Old 11-20-2017, 02:23 PM   #19
http://penncoatinc.com/
PennCoat's Avatar
Trade: Painting / Epoxy Flooring / Polished Concrete
Rewards Points: 706
I'm sure a power washer would get that right off. But not without some casualties.
PennCoat is offline
Old 11-20-2017, 04:55 PM   #20
tjbnwi's Avatar
I discovered the hard way, Krud Kutter removes dried latex.
Metro M & L (11-20-2017), TNTSERVICES (11-20-2017)
Hardwood over water heated floors questions TileWizard Flooring 11 10-28-2014 06:06 AM
Ornamental Plaster (Removing Paint) Jason Whipple Painting & Finish Work 4 09-23-2012 07:55 PM
Burnishing Hardwood Floors with a buffer? plazaman Flooring 10 02-11-2012 07:43 PM
Hardwood Floors In Kitchens DesignPlanBuild Flooring 14 11-13-2010 06:11 PM
5 Best Hardwood Floor Tips And Save Money Too! Benoakley Flooring 6 08-17-2009 12:49 PM
