Trade: General Contractor ( Central Texas)
Refinishing Question?
Is there any money to be made in the bathtub refinishing business? Countertops etc..
Trade: Pain
Re: Refinishing Question?
Of course their is money,i like working with property management co's and apartment owners the best.you make more with home owners but some times they are a pita.
Which products do you like the best? Also which equipment do you prefer? I have been looking at the Graco 3800. Any thoughts?
Trade: Pain
I have tried coatings and chemicals from about a dozen coatings mfg's from san diego to new york and for my money and ease of use the winner is midwest chemicals now located in florida.i like their wipe on primer and their 1:1 epoxy primer and hsld 5000 coatings 4 hr dry time.graco is good but all those 3 stage + turbine systems are over priced and all those expensive guns are good but a pita to keep in perfect spray ready condition.i (no bs) use a cheap 100 dollar hvlp turbine system that uses a cheap plastic fantastic spray gun that is super duper easy to clean and use.i also have the expensive 4 stage systems but dont use them at all any more.wanna buy my titan ts 50 with complete projecter set.wagner finecoat will work perfect so will harbor freights hvlp turbine system and other similar cheap systems.i have made thousands and thousands and thousands off those cheapo sprayers rain or shine you can do it.
Trade: bathtub repairs and resurfacing
I have been making good money for the year repairing cracks in tubs ,replacing fittings on jetted tubs and resurfacing the tubs.I have been using my capspray8100 with the max guns ,they work very well if you dont want to drag along a heavy air compressor around ,i still keep them in my truck as a backup , but once you buy your expensive equiptment you can do your own advertising you 'll be able to make some desent money....
Paint Pro/Faux Artisan
Trade: Painting Contractor/Faux Finisher
Has anyone repaired spider web cracks in a new fiberglass tub? One of our jobs ended up with a large series of cracks in the middle- like someone dropped a bowling ball on it. Tub was protected with plywood on top before we ever got onto the job, so whatever happened, happened before or after.
Contractor wants to get it fixed. Any suggestions? Bay Area Painting Contractor |
Trade: Pain
could be due to poor/bad tub installation.lack of support under tub creates flex in floor areas when steped on by heavy people and bottom will crack and leak water.many ways to fix,drill 1/2" holes around damaged area spray a dense foam in let dry sand bottom only, 80 grit ,patch w/fg bondo and paint bottom w/poly.you could make a rectangle pattern mix non-skid in paint and roll on with foam pee roller.
#8 | |
Re: Refinishing Question?Quote:
I'll make the suggestions-Thanks Bay Area Painting Company |
#9 | |
Trade: Pain
O tay,No problemo
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| Basement Window Question | gregt848 | Windows, Siding and Doors | 9 | 07-26-2006 06:29 PM |
