Refinishing Oak Entry Doors In Arizona
Old 02-25-2008, 08:52 PM   #1
justjeff
Jengle's Avatar
Trade: Journeyman Carpenter - B3
I am stripping and sanding two nice oak entry doors to refinish with polyurethane. The customer wants them darker (stained). There is enough damage from desert sun and a previous stripping of stain to cause problems with new stain.
Does anyone know of a blended polyurethane/stain like is available for interior applications?
Jengle is offline
Old 02-25-2008, 09:05 PM   #2
Thag
Thag's Avatar
Trade: Home improvements
Re: Refinishing Oak Entry Doors In Arizona
try that http://www.janovic.com/getdoc/29c624...-(English).htm
Thag is offline
Old 02-29-2008, 09:30 AM   #3
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
I wouldn't recommend polyurethane on the exterior. You need something that will stand up to UV rays, which in AZ you have plenty of. A good spar marine varnish would be a much better choice and then plan on going over it again every couple of years.
Stacy
S B Bolson & Sons
jackrabbit5 is offline
Old 02-29-2008, 01:13 PM   #4
BCPNJ's Avatar
Trade: All phases of quality custom residential painting work
I second the spar varnish on the exterior side. After staining, let it dry for a day minimum, Apply at least two coats of the varnish, a day apart, sanding after the first coat. Three coats varnish would be optimum.
BCPNJ is offline
Entry door frustration JLTrim Finish Carpentry 28 11-14-2007 10:48 PM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 06:24 AM
Refinishing stained and varnished garage and front doors kelsey944 Painting & Finish Work 2 04-01-2006 09:34 PM
