Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Painting & Finish Work > Specialty Coatings
Old 07-14-2008, 10:10 PM   #1
37 year installer
rusty baker's Avatar
Trade: flooring
Mixing paint with poly
I have a wood floor that needs a tough finish. What ratio would I mix poly to paint?
rusty baker is offline   Reply With Quote
Old 07-14-2008, 10:27 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Wouldn't you paint it and then put the poly down after ( I'm assuming polyurethane). To make it more durable put down additional coats of poly.
mickeyco is offline   Reply With Quote
Old 09-05-2008, 10:38 AM   #3
NAV
Trade: commercial building restoration
yea, i wouldn't mix the 2. if you paint first make sure it cures before you apply the clear coat.
NAV is offline   Reply With Quote
Old 09-05-2008, 11:58 AM   #4
General Contractor
Snow Man's Avatar
Trade: Construction Management
Dont mix poly with paint.
There is a polyuerthane paint for cars , it doesn't need clear coat ...thats laquer your thinking.
If your gonna paint a wood floor , I'd prep it properly and apply an oil primer with 2 coats of any finish you like with roll/brush .NO masking reqired, unless your like me ....I spray anything that isn't moving.
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline   Reply With Quote
Old 10-01-2008, 02:26 PM   #5
Dmax Consulting
Trade: Paint Contractor
This has trouble written all over it.
Dmax Consulting is offline   Reply With Quote
Old 10-10-2008, 10:30 AM   #6
A bit abrasive.
WisePainter's Avatar
You can say that again!
I think he may be seeking advice on what two products he should use "together".
Or at least I really hope that is the case here.
I have used TredPlex 1 part waterborne epoxy from S.W. with great results.
The product is available in any color including clear for the top coat.
Roll slowly due to bubbles that may appear.
My advice: Hire a real painter to do it.
WisePainter is offline   Reply With Quote
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
Mixing and Matching Paint?? Jethroe Painting & Finish Work 6 05-22-2007 05:27 AM
mixing your own paint HUDSONVALLEYEXT Painting & Finish Work 23 04-16-2007 12:30 AM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
