Exterior Concrete Coating Supplier Recommendation
Hi, I have to coat a set of exterior concrete stairs and I am going to throw in decorative quartz chips, what I am looking for is a recommendation for a supplier of exterior grade epoxy and a final urethane top coat.
I have used some of the companies around here in the area before but most of them do not recommend there product for exterior because of the uv. So I am looking for a source, even if they have to ship it to me, what I was recommended by one company (that I won’t deal with anymore) is a base coat, quartz (two broadcasts), polyurea, and then urethane, is this sound about right for exterior? Thanks for the input.
For what does it profit a man, if he shall gain the whole world, but lose his own soul? |
Trade: Designer/Contractor
Re: Exterior Concrete Coating Supplier Recommendation
I use alot of PPG Industrial Products. Contact your local Rep. and have him look at the job and give you a recc. i do know that epoxies are not to be used exterior as a finish coat. (UV issue). Primers are o.k. Urethanes are the best top coats exterior. Good luck..
Thanks guys for the input, I will get a hold of them tomorrow, I also found these guys but I am not sure if they are just a consumer grade product or not, but it looks pretty cool, only negative is that you have to trowel the product down.
http://www.daichcoatings.com/index.html
I'm a Mac
Trade: ICF Construction
Chris |
Dan-Liquid Art Design
Trade: Decorative Finisher
Daich coatings are good but not what you described. They have a product now that you roll, no troweling. Buy it in Oswego at Oswego Paint (bout 30 min. north of you) But check out Elite Crete dist. in Midlothian. They have a Spartic-rm urethane and all the different granule and flake choices and sizes. Incredibly strong product. Re-coats in 6 hrs.
Trade: Painting Contractor
Careful you don't create a slip hazard on those stairs.
Yes, planning on using sand/aluminum oxide as an anti slip. I still "worry" about it though.
| In need of powder coating advice | tc70518 | Painting & Finish Work | 10 | 04-14-2009 02:09 PM |
| Radiant Supplier with Questions | Kengineer | Introductions | 4 | 01-30-2009 11:11 PM |
| Coating for metal trailer roof? | buildenterprise | Roofing | 1 | 08-30-2008 09:24 PM |
