Adding An Amber Tint To Water-borne Lacquer
Old 04-19-2007, 11:04 PM   #1
djhawk
djhawk's Avatar
Trade: Contractor
A customer wants me to refinish some built-in bookcases. To obtain a
warm amber hue to these stained cases, to which I have already applied a medium toned stain, what tinting product can you suggest to
add to my water-borne, water white lacquer to achieve the desired amber affect.??????
djhawk is offline
Old 04-19-2007, 11:38 PM   #2
My custom title
Brushslingers's Avatar
Re: Adding An Amber Tint To Water-borne Lacquer
water white lacquer and amber hue don't compute. If they are looking for a "bartop" type amber finish, there are pour on style finishes for that... but it sounds like you need to check out a thread in the painting forum about amber shellac.... rich amber hue, semi clear.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 04-19-2007, 11:44 PM   #3
My custom title
Ahh.. this one... http://www.contractortalk.com/f8/spray-shellac-tips-please-21129/
Benn
Old 04-20-2007, 04:37 AM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
No additive
Amber shellac
Signature Quote
slickshift is offline
Old 04-20-2007, 10:31 AM   #5
New York City
eastend's Avatar
Trade: historic woodwork restorations
one solution, as mentioned, is to seal with shellac first, then topcoat with water-borne.
other options:
use transtints to amber-up your water-borne,
or use Target's Oxford Hybrid , which is a water born finish with an oil resin, and will impart a warmer look than regular acrylic water-borne.
eastend is offline
Old 04-20-2007, 02:42 PM   #6
djhawk
djhawk's Avatar
Trade: Contractor
Eastend, does the shellac undercoat need to be the dewaxed variety
like Zinnser Seal Coat???
djhawk is offline
Old 04-20-2007, 05:53 PM   #7
New York City
eastend's Avatar
SealCoat would definitely be my first choice.I have used regular shellac (both bullseye, and from flakes) and have not had any problems, but you never know since these do have wax. If the SealCoat isn't amber enough, try a little transtint honey/amber in it.
eastend is offline
Old 04-21-2007, 10:28 AM   #8
My custom title
I was talking more on the lines of this...
http://www.homesteadfinishing.com/htdocs/shellac3.htm
You can get no-wax shellac.
Benn
Old 05-05-2007, 07:47 AM   #9
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
if the shellac is not wax free you may have a problem with the lacquer adhering to it..my solution would be ,use amber shellac in a 3 lb cut for the depth of color you desire,then topcoat with seal coat...no problems with adhesion and safe for lacquer
painterofeveryt is offline
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
