Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Green Building
Old 09-16-2009, 08:28 PM   #1
Trade: HVAC/R
Thermal Bridging
What is the best way to prevent thermal bridging on a new home? Our village where we plan to build our new home requires, "The entire exterior must have a minimum of 1/2" OSB sheathing or plywood."
From my understanding they use 1/2" - 2" rigid foam board.
Can the foam board be placed on the exterior of the OSB and get the same results? I've heard of people having it placed on the interior side then using drywall over it. I would believe this would be more work for the electricians. Which by the way we need conduit. Also I can forsee problems with trim and base board.
Any help is greatfully appreciated.
Mike
murbancz is offline   Reply With Quote
Old 09-16-2009, 09:07 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Get rid of the studs (thermal "short circuits") and don't pay a great deal of attention to the pink panther's old fashioned static short term lab tests that are used for product identification and advertising to fool everyone into thinking a R-19 insulation will give you a R-19 wall (which will be between R-11 and R16 even with the old concepts).
Dick
concretemasonry is offline   Reply With Quote
Old 09-16-2009, 09:51 PM   #3
Trade: HVAC/R
So do you suggest using the concrete forms? I have heard that you have to be careful with getting the concrete to settle the right way in the forms. We want to build a 2-story home.
What do you recommend? What type of questions should I ask contractors when we are ready to build? What should we be looking for?
Thanks for the response.
Old 09-16-2009, 09:57 PM   #4
Trade: Remodeling general
you can use either SIPS or icf construction. another tack is to double frame the walls and leave a gap between inner and outer and insulate.
naptown CR is offline   Reply With Quote
Old 09-16-2009, 10:09 PM   #5
First you have to plan ahead and do not make any last minute changes without looking at the situation "globally", which is not the local contractors/suppliers, but products, designs and materials plus what the majority of the developed/advanced world has already discovered. - Definitely not hay bales!
Second concrete does not "settle" as amateurs think. It is placed (not poured) and vibrated into place to maximize the benefits.
I was not promoting concrete construction, but pointing out how amateurish, short sighted and provincial the current "green" systems can be, especially when you follow the energy trail back and the total cost and carbon footprint can be if you have a short life structure and the associated recycling costs. It takes money, labor and energy to rebuild.
In Brazil (the home of wood) they routinely build masonry apartments using better local materials at a lower cost and they last longer and do not require the maintenance.
Dick
Old 09-16-2009, 10:30 PM   #6
Trade: HVAC/R
Dick, what other type of products can you recommend? I'm not quite following you.
Naptown, thanks for the response. I was looking into the icf. I'm a little nervous about it.
Thermal Design insulation method bobwires Insulation 2 08-10-2009 10:29 PM
Anyone here use Thermal Imaging? timtim2008 Electrical 6 02-10-2009 09:02 AM
thermal store big moo Plumbing 4 09-02-2008 08:17 PM
windows by 'thermal Industries"--opinion davinci Windows, Siding and Doors 2 08-20-2008 07:19 PM
Thermal Expansion Via Iraq jicoll2000 Plumbing 12 12-16-2006 04:05 PM
