Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction > Green Building
Old 06-05-2008, 02:33 PM   #1
Trade: General
EIFS with siding?
Anyone know of any products that you can insulate the exterior with and use siding instead of stucco?
myshtern is offline   Reply With Quote
Old 06-05-2008, 08:28 PM   #2
Self Leveler
Trade: Epoxy Flooring & Concrete Overlays
You mean like.....insulated siding?
JBBS is offline   Reply With Quote
Old 09-14-2008, 10:39 AM   #3
Trade: sustainable construction, new and remodels
Certain companies make foam boards with nailing strips in them. You can also make them yourself and save a few bucks. I'll try to find the info on my foam slicer. essentially I take 3"-4" foam and slice 3/4 x 1 1/2 grooves and then glue ply strips into it. The important part is making the ply strips lay out over the studs, and then using a long screw to secure it.
builder brian is offline   Reply With Quote
Old 11-21-2008, 11:54 AM   #4
Trade: Siding, Metal Roofs, and whatever to pay the bills
I hang viynl over 2" foam all the time. Be sure the wall is wrapped under the eps board, sprayfoam all cracks and seal it well. I use the same washers they use on the eifs system to attach the foam
I use 3' zinc coated screws and go right into the studs to hang the siding
If your going to do alot of foam work then Id get a hotnife or build a hotwire table......routers and power saws work fine but make a hell of a mess
Red Adobe is offline   Reply With Quote
Old 12-13-2008, 11:05 PM   #5
Instructor, ex-contractor
Trade: Construction trades Instructor
You're on the right track, guys. A minimum of 1" rigid Dow or equal in combo with a 2x4 wall frame filled with r-13 glass can move the 37 to 40 degree occurence somewhere into the rigid foam layer, eliminating most dew point condensation which would otherwis occur in the fiberglass. With mold/mildew/athsma/allergy litigation building momentum on us, it is wise to learn all you can about levels of vapor retarders; and when and where to use them. Check out buildingscience.com or something like that. Just google buildingscience and you'll find it. Then go to Mold Control.....BTW insulated siding is a joke!
critter is offline   Reply With Quote
Old 12-13-2008, 11:11 PM   #6
Trade: GC/Remodeling
That's just spamtastic!
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 02:51 PM
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 15 12-23-2008 11:46 PM
Less Maintenance with EIFS or Painted Wood / siding, etc. ceilings, soffits plazaman Painting & Finish Work 5 05-17-2008 08:43 PM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 07:16 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
