Trade: Landscaping Contractor
Couple More Questions For ICF Builders
What type of exterior cover would you consider to be the least expensive (in material costs) for an ICF wall?
What type do you consider to be the fastest to install? Thanks in advance! |
I'm a Mac
Trade: ICF Construction
Re: Couple More Questions For ICF Builders
1. Vinyl Siding
2. Most Architectural Coatings (Acrylic Stucco) 3. Standard Masonary Brick 3.1 Architecural Coatings with Trims 4. Cultured Stone You could use standard 3 coat stucco, but something tells me Alaska is not a good place to do this. Hardi Plank is one as well, I don't now it's price point though.
Chris Last edited by Chris Johnson; 04-01-2008 at 12:41 AM. Reason: Added 3.1 |
Trade: lumber production and sales
Greginalaska, Simple question but not so simple answer. Most of the ICF systems have plastic screw plates on 8 inch or 12 in centers imbedded in the foam inside and outside and they should be clearly marked. But I know of at least one contractor who had trouble finding them or cutting siding material to fit and end on the plates. Most say it is not a problem except for the fact that you usually have to install housewrap or membrane (for below grade foam) and your attachment points are concealed. Some builders skip the membrane but I don't think that would be acceptable where you and I live, polystyrene and urethane loose much of their thermal resistance if saturated or the joints leak. Providing capillary breaks in walls is code in British Columbia since 2004.
So strap your walls and install house wrap over it above grade. Try to keep track of your attachment points at the top and bottom below grade and line them up as you stack the blocks. Hardi plank is good and uses recycled plastics. I would use red cedar in the northwest. Stucco below grade. Post a picture of your choice. Last edited by sawyerEd; 10-17-2008 at 12:56 PM. |
I'm kinda late, but thanks for the replies guys!
I have another. Let's say you build the ICF walls and then don't have the money to put siding or whatever on it until the next summer, what would you do to protect the foam? Or would you just make darn sure you have the money first? Oh Ed, just noticed you live in B.C....I've gone through many times. Never been to another place that has so many animals!. We always enjoy watching them as we go by. |
If you paint them to protect the surface from UV exposure, you would be fine. Keep in mind you may compromise the exterior system if you do this....like the acrylic stucco. For brick or siding, it would not matter.
I'm a Mac
You're suppose to cover it within 30 days, no one does on Custom or Commercial. I have seen it exposed for 1 1/2 years without protection, it was brushed off (yellow residue from the exposure) and then covered, no problems.
Chris |
Thanks guys, so I guess no problems with water absorption? Hmmm I guess when it is made into a cup, nothing gets out of it...so probably not ey?
#8 | |
Trade: contractor
Re: Couple More Questions For ICF BuildersQuote:
I've thought of that mic...it is our most common siding material. heh
| Couple questions from the new guy. | n4rb | Pressure Washing | 3 | 01-27-2008 05:06 PM |
| Pricing questions | Brian | Painting & Finish Work | 3 | 10-13-2007 09:38 AM |
| Couple of questions about expansion joints. | ruskent | Masonry | 3 | 08-20-2007 03:53 PM |
| Couple basic tiling questions | fast pasquale | Flooring | 10 | 06-26-2007 02:40 AM |
| Couple Questions | lukachuki | Masonry | 8 | 07-10-2006 09:34 PM |
