Plumber / Carpenter
Constructing Geothermal Heating/cooling
The previous thread was concerning cost and efficiency.
I was looking into this after the Longwood College here in VA installed it. Then I saw an episode on TV where they used it in Texas in bus stops and offices. I have 15 acres of land so after seeing all the different articles this is what I come up with to save me some money. I can dig maybe say 6 trenches, 6 foot deep x 2 foot wide x 100 foot long. Lay 1 inch black roll pipe in the ground, maybe 3 per trench. Then cover them with maybe 1 foot of dirt then compact this so as to maintain contact with the soil, then finish backfilling. Next I can install a coil into an existing furnace and connect the water lines to this. I will install a pump, and a check valve along with a 50 gallon air ballast tank (The type used for well water, this way the pump does not always have to run) and a filler tube. Next I could use our drinking water to fill the pipes, use an air compressor to bleed out the air, then seal the line off. I can incorporate the thermostat to the pump to regulate when the pump should come on. Water runs through coil, the fan blows across coil and voilą, heating/cooling! Whats your opinion, do you think this will work? I am not a homeowner, I am a licensed building contractor and licensed plumber, so I do have the knowledge to work things out. |
Re: Constructing Geothermal Heating/cooling
buy the equipment and it does work-it's not voodoo magic
![]() there are open and closed systems and even some you can lay the tubing in a pond-enjoy the watching the geese swim while your house is warmed by the pond (lake)! Seems the cost to have a contractor do the work is in the 15-20k range around my area but the materials may be had for less than half (possibly as little as 6k if you really shop it) |
| Geothermal | Norrrrrrrrrrrrm | Green Building | 19 | 01-31-2008 12:18 PM |
| constructing a ramp in a church | 72chevy4x4 | Carpentry | 13 | 11-23-2007 03:52 PM |
| Geothermal feedback | DrywallDog | HVAC | 10 | 08-18-2007 07:23 PM |
| Geothermal, heating more fiction than fact? | woodmagman | HVAC | 2 | 03-02-2007 05:00 PM |
| Geothermal Heat and AC | quickfix | HVAC | 8 | 01-14-2006 09:02 AM |
