Concrete Storm Shelters And Concrete Earth Shelters
Old 06-17-2011, 07:27 PM   #1
afton allen's Avatar
Trade: concrete construction
Been in construction 40 plus years. Started building storm shelters and built my own concrete house. Need advice on marketing on shoe string budget
afton allen is offline
Old 06-17-2011, 08:21 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Concrete Storm Shelters And Concrete Earth Shelters
ICF is the future, all the manufacturers are doing the advertising, you just need to promote yourself as the installer, suppliers and distributors will give your name out if you are good and commit yourself to the business
Chris
Chris Johnson is offline
The Following User Says Thank You to Chris Johnson For This Useful Post:
Joasis (06-17-2011)
Old 06-17-2011, 09:28 PM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
I don'y know if the various ICF companies have ever been able to pass the FEMA requirents for projectile intrusion. It took the wood people many years to meet the test performance requirements by using closely space 2x6's with lamitated layers of steel and 3/4" plywood. The roof is a toally different story.
Fatatalties from projectiles ( wood. steel, etc.) are the most common cause of deaths from tornadoes.
The FEMA standards/suggestions are based on years of testing actual walls and also contain the important information such as anchorage, roof and especially hardware including doors (and swing direction) and ventilatation.
Dick
concretemasonry is online now
Old 06-17-2011, 09:30 PM   #4
I can build anything, anywhere, anytime. What kind of prices are you talking. I can build a concrete tilt wall house burmed and dried in, shell for $45 sq.ft. or finished $85 sq. ft. I know because I live in one. I wish I had burmed it though. I decked the roof with metal roof deck, 3" of styrofome insulation and a steel shingle roof with a hail rating of standing seam roofs and capable of withstanding 120 mile per hour winds. My attic stay the temperature of outside.
Old 06-17-2011, 09:41 PM   #5
Recently attended the National storm shelter association work shop. Very informative. My next step is to join them. More of a formality though. I use 6000 lb. concrete with fiber mesh and some concrete wire with rebar in key places. I build the cheapest shelter on the internet.
Old 06-17-2011, 09:47 PM   #6
I am trying to market my concrete earth shelter. It is tilt walls with burmede roof. Very effiecient(green) tornado proof, metal stud framing makes it fire and termite proof, and with sola, so say the solar people, off the grid and no electric bill.
Old 06-17-2011, 09:48 PM   #7
I'm a Mac
Dick, I'm not sure what they have done with FEMA, I know testing was completed and passed for a 2x4 hitting the wall at 200 mph and it passed with flying colors.
The weakest part on the ICF structure is the picture windows people put in, haha
Chris
Old 06-17-2011, 10:12 PM   #8
The National stom shelter association shoots em at 100 mph.
Old 06-17-2011, 10:21 PM   #9
I use 6000 lb concrete with fiber mesh. Bullet proof
Old 06-18-2011, 07:01 AM   #10
The last time I saw the testing at Texas for the FEMA standards, they used an air cannon shooting a 12' 2x4 at 145 mph.
The criteria is for life safety and not just having the walls standing. For projectile and life safety, the requirement is NO penetration.
As long as products and systems meet the requirements, they can be listed as an acceptible application. Because of the failure of many materials, there is pressure to relax the criteria.
P.S. - Fibers are not reinforcement, but are good for micro-crack control. Since the tests usually controlled by shear, ther wall thickness AND materials in the wall are important.
Dick
Old 06-18-2011, 07:13 AM   #11
I'm a Mac
I think your right, it was 145 mph or so.
Anyways, the ICF passed the test.
Fiber reinforced concrete does nothing for my wall strength value, it requires rebar everytime
Chris
Old 06-18-2011, 08:38 AM   #12
Small mesh does not strengthen but large fiber does replace rebar. I use wire and rebar also with a metal form that stays with the shelter
Old 06-18-2011, 09:11 AM   #13
I talked to a storm shelter builder that tested at A&M and his 4'x6'x6' tall shelter with no floor would withstand an f3 not attached to the concrete floor and epoxied to floor would take 550 mph winds which do not exist.
Old 06-18-2011, 11:16 AM   #14
Wind loads are not structurally that important if yoy follow the FEMA "safe cell" construction, since the resulting structure build for projectile resistance will usually be far more than the wind loads because of the materials used and requirement for a substantial foundation and a concrete roof.
In Oklahoma, they are frequently built and used as closets, storage rooms or bathrooms with larger doors that must be swinging into the safe area.
Above ground, below ground or in a basement they are designed for life safety and survival and that usually trumps any card a structural engineer like me can hold. sometimes it is hard to recognize a safe cell unless you know what to look for.
Afton - Has your wall configuration ever been tested and approved?
Dick
Dick
Old 06-18-2011, 12:08 PM   #15
That is my next step. The National storm shelter association wants $3500 to test. We have missed each other for various reasons but it would be to my benefit to test. That would not change my shelter. I tested the concrete, 6000 lb. with fiber mesh. It came up 3800 lbs in 5 days. Much better than 5000 lb. concrete. That is a key to marketing I am sure. It is not a certification but they are a key for advertising. My door is under review with an engineer. He did not like my first one that did not have access from outside, now it does. You can find pics on facebook at Lewis Afton Allen
Old 06-18-2011, 12:17 PM   #16
I also should say I am really trying to find a market, such as Florida for my concrete earth shelter. It would be very green, not that I am worried about global warming, but It would be tornado proof, constant temp, fire proof, hurricane proof, and with solar power, off the grid with no electric bill. I'm on a fishing trip to get my message and business out there. Joplin can be rebuilt with whole neighbor hoods of these houses. The next storm would have no deaths and no houses lost. Somebody please wake up. I can build them cheaper than wood frame houses. I have done tilt wall construction since 1977. I am not the typical contractor. I have built everything you can think of. Not an engineer but have more practical knowledge than the law allows.
Old 06-18-2011, 12:32 PM   #17
Joasis's Avatar
Rewards Points: 1,314
You would be best served by finding a techno savy person to build a web site and showcase your work....bear in mind, in many municipalities, the style of construction you are promoting would not be permitted without engineered prints. There isn't any amount of practical experience that will circumvent the rules.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 06-18-2011, 01:48 PM   #18
Yes, Irealizethis
Old 06-18-2011, 01:54 PM   #19
Dirtywhiteboy's Avatar
Rewards Points: 7,964
Are you talkin about livin in this thing or putting one out back for a storm shelter
Dirtywhiteboy is offline
Old 06-18-2011, 02:06 PM   #20
Oh no, I live in my concrete home and sell shelters. Just need marketing ideas. Build concrete and steel shelters and f about to build my first earth shelter
