Building A SIP Home
Old 02-11-2008, 08:31 AM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
Building A SIP Home
Greetings,
I'm purchasing a SIP home. I'll be doing all electrical and plumbing. Does anyone know what I'm getting into? 1.5x as long labor 3x ??? Were going over the basic electrical and a little over on plumbing. Just wondering in reality is it as easy as they say or not.
Thanks in advance
http://www.valubuild.com/fp_ranch_36x68.htm
Bubbles is offline
Old 12-24-2008, 02:47 AM   #2
God
Green_Handyman's Avatar
Trade: Handyman - Specialty contractor
Send a message via Skype™ to Green_Handyman
Re: Building A SIP Home
its all in the planning, electrical has to be pulled straight up vs the traditional horizontal, i believe the plumbing has to be done the same way. check out sips.org
Green_Handyman is offline
Old 02-11-2009, 12:53 PM   #3
ContractorPete's Avatar
Trade: Insulated Concrete Forms
For one the panels are not necessarily light at all. Make sure you have some help with some 'grunt'. Who ever is installing the panels needs to make sure that every spline / 2x6 that is connecting the panels together has the correct sized holes drilled out where the electrical chases are located in the middle of the panels. When I was installing panels I found that using a 2" arbor bit was the best bet, this way the hole will be a little over sized which will help prevent your snake from getting caught on the edges of the breaks between panels.
I found that it took our electrician 2x as long to pull his wires in the sips panels on his first house. Once he got the knack of it, he got a little quicker. He also sort of rerouted some wires a little differently to save him time in labor. You can't just drill your studs, run your wires and mount your box on the best looking stud. You got to locate your box, cut it out, run your snake, connect the wire, pull the snake then mount the box. If you have to change directions (ie going from a horizontal chase to a vertical chase) you can simply cut out up to a 6" square in the location of the chase intersections to reroute the wires.
The horizontal chases in the panels are 16" & 44" up from the bottom of the panels for electrical outlets and switches. The Vertical chases in the panels are spaced 24" o.c.
The most PITA part of sips panels is having the framers forget to drill out the chases. I know of a framer who put up a sips house for a client of ours and he totally forgot to drill out the splines/plates. He was stoked on how quick it went together...then he got the charge back from the electrician/HO....
ContractorPete is offline
Old 06-21-2009, 09:36 PM   #4
concrete21's Avatar
Trade: concrete accessories hardware
this is very professional answer for you
concrete21 is offline
Old 07-30-2009, 07:58 PM   #5
I used to think so.......
wallmaxx's Avatar
Just a framer's perspective...if I have to drill for someone else's trade - "they best be payin me matie" Or they are welcome to be there all day when I am installing to "do there thing". I don't do anything other than make sure my stuff is correct for the next trade. Too often, when I would try and "think ahead" for a guy....he would come along and not even use what I had done. No mas.
Electricians drill their own holes. Plumbers are good at that too.
wallmaxx is online now
The Following User Says Thank You to wallmaxx For This Useful Post:
knucklehead (12-15-2009)
Old 07-30-2009, 08:20 PM   #6
Tom Struble's Avatar
Trade: siding
that seems reasonable to me
Tom Struble is online now
Old 07-30-2009, 09:31 PM   #7
dhall's Avatar
Trade: Green Products, Energy Auditing and Services
One story or two story? Makes a big difference. When we do a single story we don't worry much about chases and such. What we do is cut the panel for the box and then we use a flexible drill bit to drill down through the foam and the bottom plate and into the basement. From there we wire normally. For switches you need to do a little planning. Two stories takes a little planning but most of the time we do it the same way and just drill into the 2nd floor structure. If it is your first time just give it some thought and ask questions or better yet find someone who does sips and see if they will give you an hour of explanation or better yet spend an hour on site. Contrary to what alot of people say we find that on most jobs we can do wiring and plumbing in about the same time as we would in stick built.
As far as weight sips are heavy but with lifting hooks and a crane I can assemble most panels up to 8ft x 24ft with one other helper. More complex structures may take another helper but if your panel supplier did their job they are pretty straight forward. Plus we site cut alot of our panels so we know how they work.
Just as an aside, I have partnered with another sips guy and we are starting a new home building company doing only sips homes in Northern Il and Southern WI, We will be building a demo project in the spring going for a LEEDs Gold certification. I will post on the progress and if anyone has any sips questions I will be happy to answer what I can.
dhall is offline
Old 08-21-2009, 04:16 AM   #8
15element's Avatar
Trade: wall materials
okay
15element is offline
Old 12-15-2009, 07:12 PM   #9
benvolio's Avatar
Trade: general carpenter
I've got some extensive experience in sips homes, love em with the right crew. A sky-trak is worth the money on site. For your plumbing, sometimes it's best to fir out the wall, for the electrical i hope you use a good company, I'd suggest insulspan. Any specifics I can help you with, just ask.
benvolio is offline
Old 12-15-2009, 07:52 PM   #10
Wood Is Good
Jerksticks's Avatar
Trade: Remodel
What about using SIPS to add a second story? And in Chicago, would it be hard to run conduit through them?
Jerksticks is offline
Old 12-15-2009, 08:53 PM   #11
wannabe
WNYcarpenter's Avatar
Trade: carpentry
I'm working on my first sip home as a carpenter...we've been drilling all the holes in our 2x6 splices as well as top and bottom plates....And around outside corners!
Luckily, for our first experience, the floor plan is as simple as it can get. I imagine the electric rough in will be tedious, more because of inexperience than the job itself.
I would say 2x, more because of materials to be a little more creative.... but, less drilling and stapling...laying out boxes on osb and cuttin holes and fishing wires.
I specifically asked our sip rep about a wall sconce not located on a wire chase....he said...seriously!....cut out the hole for your box....torch a steel ball and drop it in the wall so it will melt down to the chase
Plumbing...well, I don't know a lot, but I was under the impression nothing should be in the outside walls anyway....
Sorry for the BS post...I'm also very curious how things will go.
WNYcarpenter is offline
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
Help! Need a high-end custom home building company name! BiggersJunior Business 14 01-29-2008 06:36 PM
Home Building Seminars JenRan Marketing & Sales 0 01-26-2008 05:56 PM
Home Building In The South FL.FRAMER General Discussion 9 01-10-2008 11:46 PM
Concrete home denick Concrete & Paving 5 03-06-2007 04:32 PM
